Resonators Deleted!
JCSIX13
MA
Jack
2016 GT350
I cant believe that know one can make a delete pipe up that you just cut out the factory resonators out and you clamp in a new delete pipe.
Jack
honeybadger
Just don't care
COTA
Kevin
'17 GT350
TORQUEJUNKY
Long Island, NY
2016 GT350 Avalanche Gray Track Pack
I wonder if there is difference in sound between the Corsa xpipe vs having stainless sections welded in.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Really nice clean setup but , you do need to make 2 cuts bud.
Ahh, you're right. THe initial article I found said there was no cutting. Did not open the instructions to read through them :headbonk:
HMm.. Seems very pricey for still having to cut the exhaust. Unless there are other benefits, not sure how it's much of a value unless you just really, really like DIY.
TORQUEJUNKY
Long Island, NY
I think it looks cleaner and possibly have slight less raspiness to the setup as opossed to cutting in a straight picece of pipe.
JCSIX13
MA
Jack
2016 GT350
I believe Corsa sells an xpipe that does that.
I saw that but it does change the sound. I I looking for something that keeps the stock sound just more of it. I would also like a better x in the pipe
TORQUEJUNKY
Long Island, NY
Technically 4 cuts.
Providing we're talking about the Corsa XPipe, I believe it may be only two cuts, which would take place behind the resonators. In front of the resonators, the factory xpipe looks like it has a joint clamp.
Zitrosounds
Madison, AL
Harold
No sir. I've already replace my whole exhaust it is one piece welded you will have make 4 cuts
CliffClavin
Mid Atlantic
Van down by the river
TORQUEJUNKY
Long Island, NY
Maybe you two are talking past each other and I'm not understanding the nuance of before/after x pipe, but it absolutely has clamps holding the x pipe section to the front of the vehicle.
http://www.mustang6g.com/forums/showpost.php?p=1141262&postcount=95
I cut out and welded replacements myself for the resonators on my vehicle and can attest to it.
I'm still undecided between removing the resonators and replacing it with a piece of straight stainless pipe or to install the Corsa Xpip.
How do you like the sound without the resonators? Any drone or added vibrations?
Thanks,
Rob
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Me: Does this truly increase performance, or just sound? How does it compare to the standard R sound (or welding straight pipes in place of the resonators)?
CORSA: The performance over the R Exhaust won't be dramatic but the scavenging properties of the 2 Xs will have similar results to our other Double X-Pipes products.
Compared to cut and weld on the non-R, we're the superior sound by far.
If it helps, I asked Corsa about performance and this was their response. If you're cutting factory exhaust already, I am not sure the value. They claim a superior sound. I did a few side-by-side videos today and it does seem to be a tiny bit less raspy and more subdued - so some like might that. Of course, it's to really tell without the same car in the conditions using the different exhausts.
For me, I think I'll have straight pipes welded in. Cutting the exhaust either way and the 3in diameter pipe shouldn't help if you're still limited by 2.5in exhaust tips anyways.
