Redline MT-82 Fluid?
Condor1970
Port Orchard WA
Years ago, Redline stopped offering MT-90 Manual Transmission fluid because Ford changed the specs for the MT-82, and the Redline doesn't make that viscosity. However, many owners used Redline MT-90 fluid for years and said it was excellent.
I'm curious, has anyone driving a 2018+ GT tried using the MT-90 fluid? ...Results?
Chef jpd
Brooklyn, NY
Deleted member 35644
Guest
Since Redline doesn't recommend any of their transmission fluids for the MT-82 on their own website, regardless of who's tried it, I'd leave it alone.
thelostotter
AZ
2017 GTPP
They recommend MT-LV as a replacement for XT-11-QDC.
https://www.redlineoil.com/Content/files/tech/MT-LV_GO_PROD_INFO_2020.pdf
I've used it once before, seemed fine. BG Syncro Shift II works well too. I'm currently using MTL which is thicker, and definitely a bit more notchy when cold, but fine once its warm. I think it may be more appropriate for track use since the trans runs hot without a cooler.
Condor1970
Port Orchard WA
I saw the DCTF, which I would think may be closer to Ford specs. Though still not on the official list.
I personally have been using the Motul DCTF, because they do list it, and it seems to work pretty good. Also, slightly notchy when cold, but pretty good when hot.
GregO
Illinois
S550 GTPP
So, the Redline DCTF does match the Ford specs for 2018+ MT-82's?
I looked up the Ford fluid spec.
If I’m reading it correctly the MT-82 fluid hasn’t changed. Ford hasn’t moved away from DCTF for the 6 speed Getrag.
If I’m wrong hopefully someone will post a correction.
GregO
Illinois
S550 GTPP
jsven008
Mustang GT
Too thick, this is a bad idea for the MT-82 especially in cold weather. Use a thinner fluid which meets the Ford spec. (Motul Multi DCTF or XT-11-QDC)
Condor1970
Port Orchard WA
Yes, I've been using Motul DCTF exclusively since the first change. Seems to work really good.
