Rear Mach 1 emblem
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
Does anyone know where I can purchase a rear modern font Mach 1 emblem? All the ones I see online seem to be the old classic font style. Thanks.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
I think you have to search for the whole piece across the back. The emblem is made in it.
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
If the Mach emblems are the same as the GT, they are plastic riveted from the inside and Ford only sells an entire decklid assembly, not just an emblem.
When I replaced the emblem on the 2018 GT with an aftermarket emblem, I ended up putting small dents into the narrow flat area just above the decklid, and cracked one of the tabs on the camera connector, as I was prying the decklid off.
2021 Mach 1
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
Thanks, guys. I am looking to swap over to a carbon fiber trunk lid and wanted to put the Mach 1 emblem back on it, but that sounds like it might not be possible. Thanks
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Should be able to order the fender Mach 1 i would think and just use it on back
2021 Mach 1
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
I was thinking that, but worried that the side fender is not as flat. However, it might be worth a shot.
Tinpot
UK
2022 Mach 1 w 3rd pedal delete
Would a decal do ? If so, find a font you like and send it to one of the many eBay vendors of vinyl graphics.
2021 Mach 1
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
I guess, you do not have you car yet. The fender emblem is quite different from the rear one. It is bent around the fender curve and different size and design.
Picked it up this week :cool:
E=MC2
Cloud DB
Dodge & Soon to be Mach 1
What about getting a metal 3D printed one created ? Then you won't need to modify the carbon panel. Any product designer would be able to create the plans for it, even possibly create a metal tag.
2021 Mach 1
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
That could probably work. I assume they could maybe take a mold of the existing one and build off of that? I have seen some custom badge makers, I'll ask 'em.
E=MC2
Cloud DB
You can provide them with measurements, photos & answering any technical questions or questions they have. They might ask for original one so they can further look into it/explore ideas.
Good thing is they will be able to work around the carbon and bulid it around that.
WD Pro
United Kingdom
Lime GT
The trunk panel is not flat either - just a heads up if you buy a ‘flat‘ badge :like:
WD :like:
Crew4991
Phoenix Arizona / Denver Colorado
Crew
Ford Mustang GT/CS, Dodge Viper SRT10
Throw a Bullitt trunk panel on just to confuse the hell out of people! 🤣
