Rear license plate mounting
Timemachine
Colorado
2017 GT350
Looking for a solution to attach rear license plate besides using the self tapping screws into the rear bumper, anybody use "nutserts"? Or should I just say "F" it and use the self tappers.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Honestly, I would just use the self tappers. The material used there if I remember correctly is rubber. Nutserts would not work there.
NGOT8R
Adrian
2019 Bullitt
You could also use industrial strength Velcro or 3M double stick tape If you didn’t want to use screws. You would have to use a hair dryer on the license plate to soften the tspe if you ever wanted/needed to remove it though.
I’ve used nut serts recently on thin plastic. They tend to want to countersink themselves in the plastic and won’t be a good idea unless youā€˜re able to get to the backside of the bumper and install a washer to prevent that issue.
Epiphany
Global
I like to disassemble things.
I agree. There will always be a plate there. Drill a small pilot, then use the "self tapper" and the urethane won't curl.
Snakecollector
Central FL
Ron
'03 Cobra (sold), '08 Viper (sold), '20 GT500
I thought I was anal... lol Drilled small pilot holes before screwing in the self tapping screws to minimize any chance of cracks.
Also put small cushions behind the license plate to prevent any rubbing.. lol
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
This, I did that too, I used weather stripping across the whole back so there is no rub.
Sivi70980
Lacey, Washington
Mark
2019 Ruby Red GT PP1 M6
I just used a silicone frame but I just have a lowly GT lol.
RasJeremy
Denmark
Ras
Mustang 5.0 2020
I'll borrow your thread for something similar... but a tad different.
I have to take my plates off every winter and reattach in the spring when it gets back on the roads. (Due to dumb Danish tax and insurance rules)
I can imagine after a couple of seasons the holes will get torn bigger. Any solution for a setup where it can be screwed on and off mulitple times without it wearing out the screw holes over time?
Rapid Red
Woodstock GA
Greg
Not really, drilled & tapped 1/4 24, used regular bolts, very clean.
Dittio's small cushions
:crazy:
@ RasJeremy
Use a stud, keep the stick-out close to the width of the a nut, measure with the plate mounted
That will do it, even super glue the stud when threaded, keep it from backing out
460Fred
Wyoming
Fred
ā€˜19 GT350 (sold)
I’m somewhat confused here.
There are already holes drilled as I remember.
As others have stated, weather stripping works great so no rubbing. I just left some gaps to let water drain. Used a simple carbon fiber frame.
AngelDeath
CH, New Jersey
The back has no pre-drilled holes, it only has where you should place the license plate and use the self-tapping screws they provide, or you can drill a small pilot hole to avoid spider cracking of the paint.
460Fred
Wyoming
Fred
ā€˜19 GT350 (sold)
Got it.
Mine was delivered with temp paper plates and dealership frame already mounted.
That’s the way it has to be here in California.
