Rear end wobbles around corners
Lann22
Houston, Tx
Landon
2016 Mustang GT PP
I’m having some bad rear end wobbles when going around right hand turn corners only when going 50mph plus, turning left is fine. I’ve checked my rear hubs and they seam fine but yet I can definitely hear some popping from the rear end. I’ve checked the tightness of all the bolts for the suspension and everything attached to the IRS knuckle and everything seams good. I’m going to try and change out my rear hubs soon to see if it fixes it but was wondering if anyone had any info on what else could cause this issue.
  • Like
Reactions: A7X
Lime1GT
Winnipeg, Mb. Ca.
Thomas
2017 Mustang GT PP
I would be checking for a bad/weak shock absorber or shock mount. Check your sway bar link ends as well.
3star2nr
Ray
2016 Ford Mustang GT PP
How do you know it's wobbling. And why haven't u taken it to a dealership...
RaceHorseV8
Illinois
Ricky
2001 Cobra, 2004 Cobra, 2019 GT
I developed a type of wobble when cornering on a Lincoln LS that had IRS and it turned out to be worn out tie rod ends. Replaced them and all was well. With the tire off the ground if you have play grabbing the tire at 9:00 and 3:00 and rocking it that might be your problem.
It must have been a common problem on that vehicle because when I ordered the new part it was difficult to find stock but the dealer said he was expecting an order for 25 more of them. Just one more thing to take a look at. Good luck!
NoVaGT
Northern Virginia
2019 PP1 GT Kona
If the wheel doesn't wobble, don't replace your bearings/hubs just because, you have some other issue.
