DeadSpool
- Dec 1, 2019
- Fort McMurray, Alberta
- 2016 GTT
Those are tiny bolts, if your using the Kelltrac Big Bertha bolts you have to grind a couple centimeters off, not much to make the bolt heads sit flat.Is this what you’re inquiring about @WD? If so, I didn’t have to relieve any areas on my diff. for my through bolt kit install.
Steeda did tell me that some machining would be required if I wanted to run a nut on the ends of the through bolts though. I didn’t see it as necessary for my application and it’s been holding up fine for the past 3+ years.
