rear camber/alignment
Racerx009
North Carolina
Anthony
2017 Ford mustang gt non pp
Racerx009
North Carolina
Anthony
That's a 305/35 /20
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Not necessary but the eccentric makes an accurate, performance algnment much easier (perhaps the only accurate way in fact). Since toe and camber adjustments are related, the ability to make fine adjustments is important. Many shops are unaware of how the rear camber is adjusted and even if they are told about the slotted adjustment either won't do it or just bang on it a few times and declare good enough. My shop really liked it.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Toe and camber are related on the front of the car, because caster. On the rear adjusting one won't change the other very much because the rear tires aren't castered like the fronts.
Strictly speaking, no you don't need adjustable camber arms. Plenty of cars out there who have gotten their rear camber adjusted without the specialty part. Is it easier with the part? Probably, but if you're not changing it a bunch I'd save your money. The alignment shop isn't going to charge you less if you have a nice part versus having the stock adjustment.
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Literally watched the rear alignment with the digital readout. My tech took an extra 10 minutes per side iterating between toe link and camber arm before we got things dialed in. The rear suspension geometry is what it is.
Racerx009
North Carolina
Anthony
My alignment guy likes them
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Just to be clear the Steeda part we're talking about adapts the slotted adjuster for an eccentric. Steeda also makes an adjustable camber arm. The latter is a whole different thing.
tj@steeda
Timothy
Here is the rear camber adjustment kit in action:
We also have the adjustable rear camber arms
Both are great options - shoot me an email at [email protected] if we can help assist!
TJ
