Rear brake piston tools
Bob_Whit
Menomonee Falls, Wisconsin
2016 GT Premium PP
Are these really needed? I've seen a bunch of posts here & seen on TV where they change pads & rotors to upgrade the brakes but it is hardly mentioned. I'm planning to do the Powerstop change & paint the calipers but would like to know if these are needed before I start.
It's a 2016 GT PP if anyone's interested>
Thanks
chowman90
Canada
2015 Mustang GT
I bought a kit off of Ebay for 30 bucks. It helped me out.
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
Yea, the rear piston twists in. While you could technically do it without special tools, I wouldn't recommend it.
You want a Caliper Rewind tool. You can buy a kit or some weird cube thing you stick on a ratchet. Either one will work, and both are cheap.
And I'm pretty sure you can rent one for free if you're really cheap.
2016 Mustang GT PP w/ Voodoo
You absolutely need some tool to rotate the caliper back. I just use a pair of needle nose pliers tho.
Remeber its crucial to lubricate the dust boots before you try to twist the calipers back in. They tear very easily. Some WD40 works ok. I'm. not sure what the preferred lube is.
DR_
In a van down by the river
David
like a complete jerk
Never can find them when I need them so I have 3 now. They make the job so much easier.
ctandc72
VA
'19 GT 6 speed Base
I've been using needle nose pliers to do this job on multiple cars with twist in caliper pistons for years with zero problems....I figure if you have to exert that much force to turn the pistons in, you likely have another issue going on.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I used one just like this.
Also: VERY IMPORTANT!
The rear brake pads have a little dimple on the back that slides into the voids in the piston that are used to turn it back in. Make sure that the piston is lined up with the dimple otherwise you'll have your piston pressing only on that dimple and will have noisy/erratic braking behavior.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
I've been able to do this job with needle-nose pliers on some cars but not others (no real idea why - but the chance of having the pliers slip and cut the dust boot is not something I'm willing to risk any more).
I've also used the cube thingy . . . but the screw-in professional tool makes the job go so much smoother that it's worth it. These days, I get to use my son-in-law's since he got out of the car shop business.
Norm
Bob_Whit
2016 GT Premium PP
Which set do you get? All the ones I've found show all kinds of foreign vehicles & some don't even mention Ford.
Thanks
JOKER M1
Somewhere in Indiana
2015 GT Premium (SOLD)
Recommend using something, yes. I try and use the right tool for the right job so I rented the set from the auto part store
Bob_Whit
2016 GT Premium PP
Thanks Chowman90.
