shogun32
- Feb 8, 2019
- Northern VA
- Matt
- '19 GT/PP, '23 GB Mach1, '12 Audi S5 (v8+6mt)
- Vehicle Showcase
- 2
really? What about spring harmonics and float? Not to mention metallurgy failure? I also rather doubt the crank is balanced so well that you wouldn't get problematic second and third-order vibrations.Ti valves are 40 percent lighter, and they alone would ad 1500+ rpm to the rev range.
Yikes. I think you'd want peak'ish (90% of max) torque starting around 4 grand and 'flat' till 6.5, maybe even 7. Have you figured out lift, duration and phasing of the cams that could pull something like that off? And the intake volume, shape, and runner length?Max torque 8200 rpm
I expect Direct Injection would have to be scrapped. Have you actually calculated the FPM (feet per minute) of the 92.7mm stroke at over 8000 RPM? Anything much past 5000 and you're stepping into exotic territory. Unless you're going to rebuild the engine every dozen runs... Destroke down to 86 or 87 and you could probably get away with 9000RPM for a while.
You're kidding yourself with that budget. There is a far smarter answer to this silly idea. Buy and retrofit a COPO motor into the 'stang.
