Question about push clips and front fender liners
fpa1974
GA
'19 GT350R
Apparently there are 2 type of clips holding the front fender liner in place. Same OD but different clipping length (one designed to hold thicker things or things that do not have to be tight together Pictures:
Of courseI am only noticing this when I am putting things together. Does anybody know where (which positions on the fender liner) the longer ones go (there are only 2 or 3 of them the rest are the shorter kind).
Thanks!
blueovalkid
The Snake Pit
OH
Clint
08 GT500, 17 GT350, 2020 CFTP GT500
Thanks!
The two larger/longer ones go right behind the front wheel at the bottom where a rockguard/mudflap would go
fpa1974
GA
'19 GT350R
Thanks! Yes, I know about those 2 bigger ones there. Those 2 are longer and have a bigger OD. as well.
These on the other hand have the same OD as the other ones but are a bit longer. I wonder if this is random or there is a logic behind it.
fpa1974
GA
'19 GT350R
I think I kind of semi figured it out. There are a couple of places where the clips need to grab on to thicker material. They are the frame rail location and the lower rear corner one that is behind the strut. Now if anybody can explain why Ford had 3 of these longer ones on the driver side and 2 on the passenger side is beyond me. The shorter clips will pretty much work anywhere well except the frame rail location.
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
anyone know where you can get these at besides dealer? any vendors?
MikeMM
VT
2021 GT500 on order
I figured this out when i ripped my front end apart the second time. There's actually 3 sizes, but they only fit well where they're supposed to go. When in doubt, the parts cataloging is a helpful resource.
Phoenix
Central Texas
fpa1974
GA
'19 GT350R
If you count those 2 huge ones at the back then you are absolutely right. There are 3 types.
MikeMM
VT
2021 GT500 on order
The smaller ones have 2 lengths.
mavisky
Cumming, GA
Kyle
2018 GT350
I have had my front fender liners out twice now and it doesn't seem to matter where I put them. It all goes back together just fine.
