Question about meth injection?
horsepower addiction
Arizona
Nate
s550
If you’re really worried about it because You can’t run water/meth before the MAF but you can buy an intake air temperature sensor and install it in the intake or right before the throttle body. Then you wire it to the MAF temp wires. Then install the water/meth nozzle after the MAF. The new temp sensor will read the actual air temperature and the computer will be able to adjust correctly. Don’t worry about when the computer shuts off fuel because the water/meth that you purchase is 49/51% and non combustible by itself so it can’t cause a lean condition. If you’re worried about an even distribution put the nozzle as far away from the throttle body as possible or run a direct port water/meth kit. I never worried about it. Even without any tuning you will benefit from it
