Purged
tj@steeda
Timothy
NGOT8R
Adrian
2019 Bullitt
+1 on the Steeda STH kit. The spherical bearings are a real PITA to install though, but well worth the trouble. Find a shop with at least a 20 ton press. I bent the press ram on my 12 ton press trying to remove the stock bushings/sleeves.
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
I got my GT350R steering wheel for under $450, GT350R strut brace for around $320, GT350R shift knob for $100, custom dash plaque for $60.... billet spacers and solid lugs for $180. Got a full LED kit coming for under $140...favorite under $500 mod is definitely the wheel though.
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Under $500 ? Shit, I try and keep mods under a grand and fail at that.
Nickel
NC Twisties
www.instagram.com
Nick
Yep, my seats were $4k but I got a deal.
Copperhead73
Knoxville, TN
Derrick
2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
If you have active exhaust, res delete and Steeda H Pipe for $200 or so.
For a gen3, e85 is a hair more than than $600 and gives a great jump in HP.
Nickel
NC Twisties
www.instagram.com
Nick
Had mine custom done as I always do, had mufflers and resonators removed. Got some nice tone but also lost a lot of weight. Cost around $150 to do
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
2018 manifold
MGW shifter
CB005
CB762
SpeedLu
some swamp
2020 Premium PP1 Mustang GT, 2017 F-150 Platinum FX4
Is this kit still needed with 2018+ Mustangs? It was my understanding that Ford made some changes to the rear suspension to address the wheel hop issues.
NGOT8R
Adrian
2019 Bullitt
From what I could tell when performing my install, there was still potential for wheel hop on my ’19 Bullitt. If you don’t intend to drive your car hard and do hard takeoffs in 1st gear, then you can certainly bypass this spherical bearing portion of the STH mod. The parts in the STH kit can also be purchased separately. After watching this video, I knew I had to upgrade. I wanted to eliminate all wheel hop if possible to greatly reduce the chance of broken half shafts.
Here are other mods for under $500. Mod #4 works very well with the STH components.
1. Short throw shifter (if your car has the MT-82 trans.)
2. Ford Performance Oil Separator (catch can)
3. Cold Air Intake
4. Differential Bushing kit.
5. Jacking rails
tj@steeda
Timothy
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Steeda's STH kits do waaaay more than stopping wheel hop.
Their real benefit is completely settling the rear end in turns, especially bumpy turns.
Night & day.
