Purged
fmc_smt
Cottonwood , Arizona
A smaller pulley ...........lol
kiksbutt
NOVA
Mustang
Steeda's STH kits do waaaay more than stopping wheel hop.
Their real benefit is completely settling the rear end in turns, especially bumpy turns.
Night & day.
Are these needed in performance pack cars? Like even pp2?
Semp1
Valhalla
2018 Mustang GT PP1 Magneride
MGW Short Shifter
Rogues Gambit
Eatontown, NJ
'07 A4, '19 Ram Rebel
Rear diff gearing upgrade - depending on your ambitions with the car and what your stock rear diff gearing is currently - a change in rear diff gears can definitely add joy to the equation...
Bullitt0819
Modesto, CA
Bob
2019 Bullitt Mustang
From what I could tell when performing my install, there was still potential for wheel hop on my ’19 Bullitt. If you don’t intend to drive your car hard and do hard takeoffs in 1st gear, then you can certainly bypass this spherical bearing portion of the STH mod. The parts in the STH kit can also be purchased separately. After watching this video, I knew I had to upgrade. I wanted to eliminate all wheel hop if possible to greatly reduce the chance of broken half shafts.
Here are other mods for under $500. Mod #4 works very well with the STH components.
1. Short throw shifter (if your car has the MT-82 trans.)
2. Ford Performance Oil Separator (catch can)
3. Cold Air Intake
4. Differential Bushing kit.
5. Jacking rails
Steeda has a 'Stop the Hop Starter Kit' w/o the spherical bearings; very pleased with it.
shogun32
Northern VA
  • Lethal/BMR/Steeda $50 grade 12 Diff bolt kit (for the sleeves if nothing else)
  • Whiteline IRS 'drop-in' version bushings ($70)
  • Steeda IRS alignment dowels
  • Steeda clutch spring ($30, M6)
  • Steeda shifter bracket ($70, M6)
  • proper alignment
  • quality cigar or bottle of OH group (market)
With shop labor you should still be under $500. These are MUST-DO IMO for every car within the first week of ownership.
shogun32
Northern VA
absolutely. The platform is rife with bad choices. The $28k ecoboost and $63k GT350 all SUCK HARD in the same way.
tj@steeda
Timothy
Also, we have forum discounts to get you even further below the $500 bogey ... as well as possible Black Friday savings coming up :)
TJ
shogun32
Northern VA
pity they don't actually post the dyno charts.
