Andy13186
I found out why my 1-2 and 2-3 shifts felt so shitty... the car is pulling 30.5* of timing on the 1-2 and 2-3 shifts in all modes except drag mode. Even with advancetrac off. And with shell v power 93 octane....
What the hell? I reset the timing advance right before many pulls and every time a shift felt shitty it logged like -30* of timing
It only happens on the 1-2 and 2-3, I tried 3-4-5-6 and those dont or barely pull timing. And in track mode timing didnt go negative.
You can see here on the bottom right after a 1-2-3-4 gear pull in track mode with advancetrac off its pulled 30.5* of timing on the 2-3 shift and the car fell flat on its face for a second..
Here is after a 1-2-3-4 pull in dragstrip mode you can see timing didnt go negative :
Is this normal? what the hell could the problem be? Knock sensors too sensitive?? IDK what this is but its a bone stock car. I do have the cold tapping noise also until the car is warmed up.
Every time I did a pull the knock went to 2 also.. is this all by fords tune design?
