whatsup62
In all honesty the two biggest pain points are removing the front fascia...and that's only for the fear of breaking clips. The second is the discharge hose on the head unit...not hard just tedious.
After just installing a "bolt on" lift kit onto my jeep this weekend.Install is cake on the stage 2. No harder than the stage 1. I posted a ton of pics on my build thread. The pulley is cake to put on. The only hard part was moving the front sway bar back and the word hard is an exaggeration here. 2 out of 10 on install difficulty.
That looks way off , it shouldn't be close to the fan shroud at all and for sure not touching... wonder if you have the blower mounted incorrectly on the plate... Something is off for sure...Thanks for the fast reply [MENTION=11041]ProChargerTECH[/MENTION]
Could you let me know if anything looks a bit off here? Its already been trimmed so as long as im not running anything risky I could leave it
You can rotate the "snail" and you will be all good.Thanks for the fast reply [MENTION=11041]ProChargerTECH[/MENTION]
Ill let [MENTION=11041]ProChargerTECH[/MENTION] chime in but I think you need to re-clock the head unit one bolt counter clockwise. take a look at mine. I am stage two so their might be a difference but you head unit is clocked straight up and down and mine is canted to the right.This is the top view
you're fasttttt with the repliesYou can rotate the "snail" and you will be all good.
Send me a PM with your serial number.
I want to log this.
