Procharger Crank Support:?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I agree alex can definitely be biased against certain brands like procharger and BMR. I just hope the MFP version of the crank support allows you to keep the front sway bar. Probly doesnt matter though because after i get my car dynoed and run a 9 in the quarter, gonna sell the procharger and get a real blower like the gen 3R. Less likely to snap the crank and instant torque. Plus having a circle d converter its loose AF until you go WOT.
Good luck!
fuelforfire87
IL
2014 Shelby GT500
SolarFlare
S. Fla
2015 CO GT
fuelforfire87
IL
2014 Shelby GT500
Good numbers. I heard yolo mention it.
so it made 750ish uncorrected? I saw 8% correction. 4.25 on D1sc must move well.
I wasnt paying attention to the correction factor but yea i guess if its 8% then thats 750 uncorrected. Took it for a spin after the tuning was done and it hauled A** even in the hot weather
fuelforfire87
IL
2014 Shelby GT500
Another strange thing i noticed is that even though i switched from a 4.5 to 4.25 pulley i checked my boost in the logs (boost box omega) and it still peaked at 13 psi same as when my motor was stock and running the bigger pulley. The new heads and cams must have helped the new engine breathe better
fuelforfire87
IL
2014 Shelby GT500
Yea I don't doubt it. You kept it at 11:1 compression?
Yes sir, 11:1. didnt want to drop compression since i"m running E85 all the time.
fuelforfire87
IL
2014 Shelby GT500
What is the complete setup?
MMR 1000 short block 11:1. Boss 302 heads. L&M Intake cams. Boss 302 exhaust cams. Bret Barber ported Boss 302 IM. Stock throttle body. Procharger stage 2 kit D1SC with the race intercooler and red bypass valve. Kooks 1-7/8" headers, lethal over axle pipes. Corsa quad tip sport axle back
fuelforfire87
IL
2014 Shelby GT500
Also built stage 3 6r80 with clutches, intermediate shaft and billet planetary gear. Circle D 3C converter
Vector
Ohio
S550 A6
What's your fuel system
Pumps, lines, rails, injectors
Thanks
fuelforfire87
IL
2014 Shelby GT500
Thanks
Fore innovations twin pump fuel system. Walbro 465s. PTFE lines 10 feed and 8 return. Id1300x injectors
beefcake
Bethel
2018 Ford Mustang
FYI, procharger has been making crank supports for years and years fro their cars. They didn't rip anything off from MFP.
We have sold more blowers than anyone over the last 10 years on these cars, id venture to guess 6-8000 kits, and the number of cranks that have actually failed that customers have messaged me on is probably 3.
Thats all brands. I get its the hot new item, and people like peace of mind. And of course we'll sell them if people want them. but i think the hype is a little overblown.
