Prochager or Whiple
fmc_smt
Cottonwood , Arizona
So what is your guys best answer ? Looking to do one or the other .
Boduke0220
NC
2015 GT PP
I went Whipple. It’s downright violent lol
fmc_smt
fmc_smt
All right I've already done the 18 mani upgrade , thoughts change ?
Barrel
Hoonigan
Cars and Trucks
I went ProCharger...
Like asking what flavor ice cream you like. Everyone knows the answer is french vanilla with caramel topping, they just want to lie to everyone else that they like rocky road.
Ryan_s550
Baytown, Texas
2016 Mustang GT, 2013 GMC Sierra, 2015 Maserati Ghibli
I'm looking at a Stage 2 ProCharger D1x or a Gen 3 Whipple myself. I'm about ready to pull the trigger since I've got all of my other mods to be "boost ready." Does anyone have dyno graphs of cars that would be comparable using a D1 or D1x vs a Whipple at the same boost numbers? I figure the best comparison would include an intake manifold on the centrifugal setup to help it make power up to 7500rpm. Obviously the Whipple is going to make more power on the lower end of the graph, but I would mainly like to see what happens from 4000-7500 rpm. If anyone has experience or educated opinions please chime in!
GT2
NEVERADA
NADA BRAH
:lol:
http://lmgtfy.com/?iie=1&q=lol+dyno+graphs+lol
SoCalTim
CA
Tim
Sold : 15 GT
Beefcake Stage 2 Paxton :D
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Heat soak with a PD blower is real down here in the south. Go centrifugal or turbo. I have had them all. Presently I am centrifugal
yote41
pa
16 gt
I agree.the down low is nice on a pd blower. But heatsoak is a huge issue. I have had 03 cobras. Tvs.kenne bell on previous cars. All run HOT and you can feel it in the car and see it in iats. My current procharger setup is tame down low but you feel like you are on a jet on a catapult above 3500rpm. And it runs cooler now then when i was NA
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Heat soak is not an issue on the newer S550 setups, and can't compare to old setups. Comparing with older generation PD or twin screw setups the new S550 setups have much more efficient rotor packs and the HE and intercoolers are much bigger and better designed. Many people run these without issue and heat soak isn't something to worry about. Problem some may have is running an open filter in the hot engine bay, not good! Run a closed airbox on a PD setup for sure.
Boduke0220
NC
2015 GT PP
My IATS with the dual fans are 25-35 degrees over ambient. if I had an ice tank it would be even less. that's pretty good IMO
NightParade
Houston
Justin
Magnetic 2017 GT PP
I have a procharger stage 2 D1SC and really love it. Pros are easier setup and less complicated system overall, low aits like normally always a few degrees above ambient temps. It pulls like a beefed up NA setup so drives normally in the low end and ramps up like crazy above 4500. Pair it with 2018 manifold and your golden. Whipple will have a more initial torque feeling off the hit and pull strong as well. Cant go wrong with either just depends on goals and use of the car.
