Procal return to stock
BenGTPP
Sacramento
Ben
2016 Mustang GT Premium PP
The instructions are vague. I have two PC3 files the original PP2 tune and the updated one. I hit restore and it erased and loaded what I assume is the factory tune, sound correct? If the stock tune has a separate PC3 file I am going to have to shake ford down for it. It was specified on my Ford service order to store factory calibration on customers laptop.
1MeanZ
Indiana
Jeremy
2016 Mustang GT PP M6 1986 Camaro IROC-Z
If you have the Power Pack 2, I don't think you can run the stock tune unless you put the stock throttle body back on....
thelostotter
AZ
2017 GTPP
Sounds like you did it right.
Open the pro cal software
Open your tune configuration file
There will be restore option available. The stock tune will be embedded in the PC3 file that was created when you originally flashed the PP2 tune.
BenGTPP
BenGTPP
Sacramento
Ben
Sweet, that was the answer I was looking for. Just wasn’t sure if there was a PC3 file for the stock tune or if was lumped in with the PP2. Have to revert back to stock prior to supercharger install. Thanks.
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
What if the dealer was the one to flash the PCM originally? Anyway to recover the stock tune? I have PP1
BenGTPP
BenGTPP
Sacramento
Ben
You need the PC3 file in the Procal calibrations folder to “restore” the previous tune. If your computer was not used it is most likely gone. The file will be on whoever installed your original calibrations computer.
poncho@home
GettingOld
Laval, QC
Dealer used their laptop. I don’t remember if they used my USB where I had downloaded the procal calibration before going to dealer. I’ll have to take a look at it to see if there is anything on it
