Wastegate? Never heard of her3.33 (if not wastegated) and a manual should make north of 800 on e85.
Possibly, not sure it's a huge difference given a long pull in 5th at 1:1, but partitally why I kind of want to dyno with my 28" ET Street R's however I feel that would do more harm than good due to drag. I could always give it a show with them aired up a bit though. Still debating as I want to visit mexico right after, lol.I think A will be higher than B simply because of the gearing. Numerically higher gears tends to artificially swing dyno numbers down. Same effect between stiff wall tires or slicks on a dyno...
Does that say 850?!
Stock motor? Gated or no if so what are you blowing off at 16psi?
Holy hell not 1 but 2 little paxtons killing it on the dyno both over 800whp!! I feel you on that. I'm on 10 right now, once I get the new fuel system/tune dialed I'll turn it up a bit. Have a 3.31 diff and 3.6 pulley in the garage waiting. At some point I'll go 3.48.Paxton/Vortech FTW...Im not Sending it as much as you guys, 17-18psi sounds nuts, ill stick with 14... for now lol
What's your current fuel setup?That was running the 3.33 straight up, no gate, run exactly how it’s driven.
Looks like it’s running out of fuel right at 7500, might put some 1300’s in it and maybe turn 8k for those pesky turbo vettes.
Motor is 100% stock except for OPG/CS.
So recap, car A) 816/608, car B) 850/622
