MakStang
- Dec 11, 2016
- Greece
- Website
- www.cellentis.uk
- Makis
- A 2017 miraculous little beast
Can you find this type of product in EU? There's a Ford Edge Sport guy that runs this at the 1/4mi track with tune made for high octane. Not an everyday drive around town type of additive but may be helpful if you know your going to go out an play a bit!We all know that fuel is the limiting factor in terms of reaching higher power levels when using pump gas. Where I live (Europe) I only have access to 100 Ron (93+ oct) pump gas. I came across this MAP Intake Manifold at another forum. Will this add any extra benefit powerwise?
https://www.maperformance.com/colle...anifold-2015-ford-ecoboost-mustang-map-ebm-im
Thats a throttle body spacer, not a throttle body FYI. I know some others put it into the silicon coupler just before the throttle body too, not sure which option is better myselfthrottle body
1. Methanol's about 79.1% weight of water by volume. Perhaps he's trying to get closer to 50/50 mix by weight? I started playing around with ~70% mixture recently but the benefits over the 50/50 (by volume) mix will be hard to tell unit the summer hits.@Bull Run , @5.0yote I am preparing myself for the WMI setup and I had a discussion with Adam about that. I have a couple of questions:
Your feedback is greatly appreciated.
- I was prepared for a 50% methanol mix. Adam told me to use 70% meth + 30% distilled water. Is the % of methanol of any significance? Why 70% instead of 50% meth?
- He told me to use a 500cc nozzle to inject the methanol. I am not certain if Snow Performance offer a 500cc nozzle, although I am still looking into that (I am buying the kit from a supplier in Europe). What size of nozzle do you use to inject the methanol?
- Important: Where do you inject the methanol mix? Is it injected in the intake manifold, which means that I will have to drill a port? Someone suggested to use the following throttle body spacer, that has pre-drilled ports for nitrous or WMI applications: http://www.unleashedtuning.com/torque-solution-tb-spacer-2015-ford-mustang-ecoboost-black/
