Interceptor
Daily Driver
- Apr 3, 2018
- Low country South Carolina
- 2019 California Special A10
Good catch.
Well its odd to me how many people wonder about knock and ping and see error correction and never look at the Fuel first. I can tell you my story with my EBM taking to the dyno one day, the night before I was just getting the last final tune revision from Tune+ on my big turbo. Everything was fine. Next morning not thinking I stopped at my local gas station with a Dunkin Donuts and got my morning joe, and for some reason did not think about it, I got gas there. I went to the dyno and had exactly the problems you stated. Lots of knock and pinging, and I was getting significant timing corrections on random cyls. Needless to say the dyno did not go well, and after scratching my head, the only that had changed from the night before, was a really poor tank of gas in the morning.OK, let me share with you guys the problem that I run into.
About 3 to 4 weeks ago, I started hearing a noise everytime on part throttle, between 3500 and 4000 rpm on gear change (either on D or S). Initially I thought it was an issue with the transmission. I took the car to a friend of mine who is a mechanic and he told me that this noise is detonation! This got me worried.
A couple of days ago, on Saturday, I took the car for a long drive, about 210km each way. An Audi started following me at 180kph (112mph), so I did a wot to show him some real muscle (lol). The Accessport was connected on the car, because I was monitoring knocks on cylilders 1 to 4 and ignition timing correction on cylinders 3 and 4. During that wot I noticed a major negative correction on cylinder 3 (-6.5). So next I decided to do a datalog while on the highway and I did another wot. At around 220kph (137mph), the car went to limp mode and the AP recorded multiple knocks on cylinder 2 and 3...
The datalog was sent to my tuner who told me that the headgasket is probably staring to go. I changed the spark plugs, just to rule them out, but I still had detonation on gear change at 3500 to 4000 rpm. Apart from this detonation, the motor feels fine, like before.
I took the car to the dealership and they will install the JE Pro Seal headgasket and ARP headstuds next week.
I believe that the stock block cannot take the extra power even of a drop-in turbo. I had a near-ecoboom experience and I was lucky enough to avoid the worst... If you want my advice, an upgraded headgasket and headstuds should at least be installed alongside the PTE or any other drop-in turbo. Although forging the engine with upgraded pistons and rods would be the ideal way to go.
However I would like to hear your ideas on the above. What could be the cause of the detonation that I hear on gear change at part throttle between 3500 and 4000 rpm? And why do I get knocks on cylinders 2 and 3? Is it really the headgasket?
I appreciate the input. Also this is the link to the datalog I referred to above:
@Juben @Glenn G
Glad to hear it is working out, yeah I was just pointing out people seem to overlook fuel too. =)Thanks for the input @5.0yote . In my case it was neither the fuel nor the spark plugs. It was a defcetive head gasket. It seems that coolant was leaking in cylinders 1-3. Cylinder 4 was the only one with no issue. As I said above, they checked everything (pistons, rods, even the cylinders for possible deformations) and fortunately there is no damage whatsoever. They have now prepared the head and they are ready to put it back on, with the upgraded head gasket and headstuds.
I hope to have her back before the end of the month.
Shipping the motor alone would cost more, I'm in Australia. I don't think there are any local engine builders for this platform.Isn't the labor if changing out the gasket and studs enough to justify just building the motor?
All work is done under warranty, so I am not paying anything (well just the new headgasket and headstuds).Isn't the labor if changing out the gasket and studs enough to justify just building the motor?
Yeah, Adam was able to diagnose a faulty headgasket as soon as I sent him a description of my issues. Yes, a faulty headgasket is the reason behind many ecobooms. Faulty headgasket means coolant and oil in the cylinders.Wow, good catch... and, my hats off to your tuner (Tune+) for having enough experience to make a good troubleshooting recommendation. I bet a lot of the ecoboom issues are probably related to faulty head gaskets as well.
Here are two datalogs, blue is NX2, red is stock turbo. Identical mods otherwise, tune was obviously changed between them. Take the power figures with a grain of salt due to being from accessport logs and virtual dyno, but the boost stats are a straight graphing. Stock turbo was colder weather too.I'm really curious about the boost curve of these turbos. Can anyone provide some insight or a datalog? Curious how spool up compares to stock turbo.
