Power outlet in center console
Beezpony
Northford CT
Howard
2019 Mustang GT
Hi Everyone: I am looking to hook up a trickle charger and would like to know if the power outlet in the center console is live all the time or just when vehicle is turned on? Manual infers all the time but not clear. is anyone using it for winter trickle charging?
Thanks.
Sig556
White18
North Carolina
Ed
2024 GT Premium / Iconic Silver 10 Speed Auto
Thanks.
Try using a TEST LIGHT that will tell you in a heartbeat if the circuit is hot. If the light lights its hot all the time. If it only lights when the key is on well you know!
I Bleed Ford Blue
North East OHIO
Most trickle chargers come with a pigtail that hooks directly to the battery with little ring terminals, then you just plug it there. That's what I did with mine, and they even have caps for the connector to keep it clean and dry until you need it.
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
That is what I did with mine. The lead pokes out by the wipers with a rubber cap on it to protect from the weather. means it is easy to plug in to the charger without any leads through doors / bonnet (hood) / boot (trunk)
Beezpony
Northford CT
Howard
2019 Mustang GT
To All: Thanks for the replies. I have used this method on other cars. But in this case I happen to have a charger that came with a prior car and it used a connection using the aux power plug. So I plugged it in (console power outlet) with the car shut down, and the light indicating power is on was illuminated on the charger, so the plug is live with the car shut down.
SAL-E
Casa Grande, AZ.
Gary
2019 GT Ruby Red
Check to see if it turns off after a period of time. I haven't tried the center outlet, but the one on the dash seems to cut off after a while.
Beezpony
Northford CT
Howard
2019 Mustang GT
Good advice, thanks.
tokuzumi
Atlanta
2004 Escalade ESV
I know the outlets in my S197 were live all the time. Only American car manufacturer that has switched outlets that I can recall is Chrysler. My 2012 F150 had 4 accessory outlets which were live all the time.
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
There is a general power cut off after 10 minutes, so if you are checking circuits immediately after you turn the key off, WAIT 15 minutes for the car to power down everything.
If you open the door, all those circuits close again so you have to wait 10-15 minutes again. PITA.
Beezpony
Northford CT
Howard
2019 Mustang GT
Yes but the odd thing is, if i plug my charger in while it is still hot, it remains powered on for quite a while, i tested it up to 3 hours or so. But given the odd way it works I am opting to not use that charger, I am going to buy one that I can connect directly to the battery. Much more predictable. Bought another ctek 3300.
