Popping from throttle body?
Kong76
Turlock, Ca
2016 Ingot Silver GT
My car is doing the same exact thing. Took it to the dealer and confirmed its the throttle body. Said its not covered under power-train and is approx $500 to replace. :curse: Better off buying an aftermarket one and doing my self.
Run as fast as you can. The stock OEM TB is no where near $500. I found them for $90 on Tasca Parts. If Cobra Jet can supply the ssm don't they have to cover it?
* $115 not $90. Price went up from a year and a half ago.
fmc_smt
Cottonwood , Arizona
Only a fsa would extend the warranty not a ssm or a tsb
Here ya go - this is the initial thread I had posted and member fmc_smt provided additional info in it too:
https://www.mustang6g.com/forums/threads/2018-19-5-0-throttle-body-replacement-18b34.115976/
IF the vehicle is still under warranty (3/36 OR an ESP), you should be able to get that TB replaced by Ford, as it IS a known issue. Go to another Dealer if that Dealership is trying to rob you of $500.
If I were you, I’d call the Ford 800# and get a CSR to do a claim and reference the article noted here that it is again a known issue and YOU shouldn’t have to be paying anything.
Louieg58
Los Angeles, Ca
2016 mustang gt performance package black
Thanks for the info. The issue completely makes sense, but I notice the bulletin only mentions 2019 mustang 5.0s- mines a 2016. Other issue is I am out of 3/36 warranty. I still have power-train, but of course Ford doesn't define the throttle body as a power-train part. I am already going through Ford 800# for a separate reoccurring AC issue with the car as well.
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
I just had this issue start today. It only does it a few times then stops. The car seems to drive fine and sounds fine when I give it gas. I'm still under warranty, so I'll probably bring it in and have it replaced eventually, but is it something I should get replaced right away? Could it cause more issues if I continue to drive it?
