ImmaJosh
- Apr 2, 2021
- Toronto Ontario Canada
- Josh
- 2018 GT350
NopeDo you have any mods?
As in the oil change was fine and the oil pressure seemed fineEngine temp was running fine and in fact the non digital gauge for it said it was more cold than anything even though Iād be run all day. In fact there was no check engine light or anything that went off when it started messing up. It just got an oil change but no signs of it being put on wrong.
Nope. StockSounds like a rod bearing to me. Do you have mods/tune?
Then I don't see why they wouldn't warranty it.Nope
Did you check the oil? Wonder if they didn't put enough in...As in the oil change was fine and the oil pressure seemed fine
I heard something about misuse but I really only did a normal acceleration to about 6.5k maybe 7.Then I don't see why they wouldn't warranty it.
10 quartz was put in. Same as they said.Did you check the oil? Wonder if they didn't put enough in...
Dip stick showed that there was still oil in there.Did you check the oil? Wonder if they didn't put enough in...
And quite a bit actually.Dip stick showed that there was still oil in there.
Since your stock you should be good. Besides an occasional pull shouldn't be considered abuse. Even if you did ford has to prove you abused the car being stock is going to make it hard to prove.I heard something about misuse but I really only did a normal acceleration to about 6.5k maybe 7.
... my hazards were on because when youāre on the side on the road and your car is making a knocking noise, you usually keep your hazards on to not be impolite. If you can ignore the hazards and actually pay attention to the video and give input, thatād be great.Sounds like a turn signal to me.
