Paxton Upgrade
beefcake
Bethel
2018 Ford Mustang
I'd like to hover in the 1k wheel range. I figure a YSi, non billet, and a modest bottom end build would suffice.
a jt will get you there, i would go with the billet jt over the ysi
little more responsive down low, and doesn't drop off as much up top
thatonenozz
Chino, CA
2015 Black Mustang GT PP
Doing any Black Friday Sales on JT-B head units? :D
higdominator
Central Oklahoma
2016 GT PPP
Right on.:headbang:
beefcake
Bethel
2018 Ford Mustang
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Sutton was on a 3.15 pulley lol
Pincushin3819
SC
17 Paxton GT
What about the YSI-B vs. the JT-B? Does it still fall off up top or doesn't have the same responses down low?
beefcake
Bethel
2018 Ford Mustang
for 1000 wheel, i like the jtb, for 1100 the ysib
Tatum337
GA
2016 GT
brackets
I'd think the V3 kit brackets are the same as the 2200SL. Maybe a market to those Vortech guys who want to put a larger unit on but not go full retard.
The brackets are the same for the Vortech kits all the way to the JT b head unit. Just upgrade myself from the Paxton 2200SL. Got out before I tore it up.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
buddy of mine just put down 896/735 with his Paxton 2200 sl 3.47 pulley overdriven %15 balancer ported heads blower cams built motor 8 rib set up on e-85. he's over spinning the blower 11,000 rpm.. peak boost is 24lbs. and its a stick tremec car...
Dominant1
Dr Frankenstang
dang wonder how long the little paxton that could will hold up like that!
His tuner has one of his own that's been over spun 22,000 rpm for 2 years now no issues...the problem is the higher rpm drop off with the 2200 sl... the jtb with its billet interiors and extra fan blade doesn't drop off, it keeps making power ...
Barrel
Hoonigan
Cars and Trucks
And probably making a ton of heat. 24 # and only 900rwhp? I make more than that on 6 # less of boost with my PC. That kind of inefficiency would make me nervous.
Dominant1
Dr Frankenstang
Im gonna get A D1x here pretty soon. the stock pulley is 13 lbs of boost. should be good for 775 rwhp..on e-85.(beef i'm buying it from you) just getting the funds together...
gearhead2685
Back in North Dakota
2016 mustang
You are on of the very few that ive seen over 800 on a PC let alone over 900 on a D1.
You on E85 or whatelse is done?
Barrel
Hoonigan
Cars and Trucks
I've pushed the D1SC as far as it can safely go. Nothing magical about my motor. Forged rotating assembly and cylinder supports. Then just E85, GT350 IM, GT350 TB.
OPG, TG, ATI balancer and a really good tune. Stock heads, cams, and valve springs. I spin the motor to 7500rpm.
