Passenger Side rear cradle not aligned after dropping!
WD Pro
United Kingdom
Lime GT
Oh my god that makes sense! This has stressed me out much more than it should have, the fronts were so much easier:(. So loosen bolts -> stick something inbetween the bushing hole, and the chassis hole and pry it so that its aligned, tighten them and do the same with the other side?
The subframe isn’t a noodle, you will struggle to move one ā€˜corner’ if the other three aren’t backed off enough to allow some movement / compliance :like:
WD :like:
StangTime
Ontario šŸ‡ØšŸ‡¦
Todd
19' GT PP1 Manual
Didn't think about unbolting the shocks, will do that tomorrow morning to alongside all the other advice, thank you so much!
I wouldn't bother messing with the shocks. They have enough give that they are not going to prevent aligning the subframe. I left my shocks fully bolted up during my last subframe drop and could move it around no problem supported on a jack with extension arms. You may need two jacks to support the subframe on either side of the differential. I don't recommend using the diff to hold the weight of the subframe as the diff brushings are far too soft and can tear.
uhChange-
uhChange-
Nevada
2015 Mustang GT
Alright so just an update to this thread… i got it all back together. I did not realize that my new coilovers were tight enough to where there wouldn’t be any rotation when i was prying the subframe. Unbolted the shocks -> unbolting every other subframe bolt-> started adjusting.
I needed help from a friend. While the whole cradle was dropped I used a prybar on each side, aligning as close as i can and while my arm was pushing on the bad, i had my friend slowly jack the car up. Once the cradle was high enough I put in the front subframe bolt pretty far in, but left some room.
Thus, the other side was slightly out of alignment. But since i left a little room on the other side i was able to rotate it just enough to get it to align. I put all the bolts in and tightened it in a pattern, just to keep it all even. Torqued them down and finally off to the alignment shop, wasn’t as bad as i thought the subframe moved very easily.
