jayhoogs
- Mar 1, 2021
- New Jersey
- Jayson
- 2022 Mach 1 HP
I have been having an issue with my parking brake for a long time - several months. I am aware of the common necessity of adjustment of the cable near the transmission, and I have done this, but it does not fix the issue. The handle itself is fine, it pulls tight after a few clicks and feels relatively normal. The problem is that the brake does not hold whatsoever; it is as if absolutely no brake at all is being applied. I have been relying on parking in gear to hold the car, but I really would obviously prefer having the parking brake working as well. Today I took a closer look at the calipers but could not figure out what was wrong. One thing I noticed was that the lever that the cable is attached to was all the way forward, not around the 1-2 mm from the stop that it is supposed to be. I tried moving it back using the nut inside that tension spring, but once the brake handle was engaged and released, that lever would not return towards the stop but would rather stay towards the front. It seems to me like the spring is not working to return the lever to the correct position, but not sure what this means or if that is part of what is affecting the operation. Also, even with these adjustments it still did not seem like the brake was holding. Originally, I thought it would be fixed with new brake pads and rotors, but after changing those a couple weeks ago it did not fix the problem. Does anyone have any ideas or experience with this issue?
