P2005/P2007 code. Yea, IMRC stuck closed
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
102,000 miles. Old man driven. I really don’t want to do the ‘18 upgrade. Are the ‘15-‘17 intakes still available from Ford? No, not going to go with a used or China intake.
Web searching Ford parts I get part number FR3Z-9424-N. But I’m also seeing that same part number for the ‘18 intake.
Honestly, I’m just trying to avoid the expense of the tune and the hand held device. Because if I have to go there I’ll be adding a CAI as well. If I’ve gotta go there, looking at the complete kit from VMP.
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
GT350 or 18-23 are the easy buttons here. Both are more reliable.
You can run the GT350 without a tune with the stock TB and intake if you use an adapter. Not sure if it's still in production though.
People used to get the FP Power Pack 3 for both the performance uplift and reliability.
ScottsGT
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
I’ve heard you can run the GT350 without a tune and you cannot. Anyone here with firsthand experience? There are wiring mods needed.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
100% the GT350 IM is a bolt on no tune needed install. You will need a throttle body adapter VMP makes a good one.
Yes I have run the GT350 IM on a 17 GT with no trouble and no tune. I am a hobby tuner so I now have a tune for it.
PM me if you want more specific info.
VMP Stock GT 80 mm Throttle Body Adapter Plate to GT350 Manifold
PN: VMP-INA009
https://www.vmpperformance.com/VMP-GT-throttle-body-to-GT350-manifold-adapter-plate
K4fxd
NKY
Just FYI, 95% of the tune for this manifold is just raising the Rev limiter.
Pistol_91
Clearwater
2020 mustang GT
Can you not unstuck the IMRC or are you just planning to upgrade and this gave you the reason to?
ScottsGT
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
Most likely the shaft is broken since this seems to be the common issue. Now it could be the vacuum actuator. I just don’t want to tear into the engine and have it sitting waiting on parts while unmoveable in my driveway. I’m going to try and get a better look before ordering anything.
CowboyJohn
East Texas
2024 F150 STX Offroad, 2015 Mustang GT 5.0
You might be able to repair it for around 50.00. Check out this thread and the links included if interested. I did on my son's, and one of the links is from me.
ScottsGT
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
No links.
ScottsGT
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
Update:
Went with the 2018 intake, JLT CAI and the VMP tune.
Pulled the ‘15 intake off and discovered I just had a bad actuator. Oops! 😬
But I don’t care. The butt dyno says it was well worth the effort and cost.
