P1sc stg2 and 3.55
Ghosted_10spd
Tennessee
2019 gt/cs
I have a 10 speed with 3.55 gears... I’m installing a p1sc stage 2 kit on 93. I remember hearing of a gear ration that’s supposedly better for boost but would like clarification as to why that is and which gearing ratio is better! Thanks in advance
Jackson1320
California
Jaxson
2015 mustang gt
3.15. Because of the gear ratio in the transmission are very short as it is. So longer rearend gears help
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Run it on the 355 first since its in there. Then see if it needs changed. If you put together a combo based on what forum people say, you will end up with some slow shit.
Jackson1320
California
Jaxson
2015 mustang gt
Facts! This is what I’ll do
Don’t ask a question if you don’t want the answer. With the gear ratio in the trans being so low and 3.55 gears the car is going to be worthless if you launch in first. At least get a 2nd gear leave tune. Then the car is going to be shift shift shift shift shift shift shift shift shift. you don’t get a chance to use the gear. Don’t believe me email Lund
17Magnetic5.0
2017 premium mustang gt black accent package
It might be fine with the 3.55 gears. The centrifugal doesn’t make as much boost down low as a roots type supercharger.
Jackson1320
California
Jaxson
2015 mustang gt
The thing is with a centrifugal and a 10r80 it gets to full boost about as fast as a 6r80 with a PD blower. It gets to full boost right now
Ghosted_10spd
Tennessee
2019 gt/cs
Keep the smart a** remark you wrote in line 1 of your response to yourself.. it clouds the 2 cents you’re attempting to add to the post. Now to the rest of your response thank you and I’ll check with Lund !:)
Jackson1320
California
Jaxson
2015 mustang gt
I apologize if it came out that way. Smart ass was not my intention. I mean not to ask for information if you are not open to hearing people’s opinions. I probably should have been a little less blunt
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Steeda is using a 3.15 gear with their record holding N/A GT.
With these current transmissions and the 4 something first gear.....
Jackson1320
California
Jaxson
2015 mustang gt
2nd gear leave on a centri with 93oct lmaoooo.....that would be a turd for sure.
leave the 3.55 in it.
First gear in a 10r80 with 3.15 is exactly the same as a 6r80 with 3.55
All I know is Lund and other tuners recommend 3.15
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Does this insinuate something outside of the obvious?
