BigBeed
- Nov 11, 2015
- South Jersey
- Dave
- 2019 GT Premium 401a PP2
Hello all,
Trevor at PBD sent me my 93 octane base map yesterday and I flashed it and did the logs and sent them back. I babied the car on the way to work and everything seemed fine. I went on my lunch break and came back and noticed it threw a CEL so I read the codes and I got the following.
P0300: Random/multiple cylinder misfire detected.
P0316: Engine misfire detected on startup (first 1000 revolutions)
And another P0300 but it is grayed out.
I did some searching and found that when most people throw those codes, they do a crank relearn and everything is fine, but all those cars seem to have had a supercharger or a clutch installed and I have neither. I've also seen that it could be bad gas but this is the same gas I had in the tank before I tuned it and it was running fine. Could the tune be that much more sensitive? Also not sure if PBD uses an adaptive octane logic or not.
Mods are as follows
2019 GT PP2. 12,7XX miles
Factory intake. K&N drop in filter with carbon trap removed and studs for carbon trap removed and smoothed out.
MAK cat deletes
MRT H-pipe
Factory active axle back
The car seems to idle a little rough right after cold start but smooths out a bit after it warms up. I have an email out to Trevor about it but I need to drive it later today and I probably won't hear from him until Monday at the earliest as it is the weekend. I kinda don't want to do a crank relearn or clear the codes without him weighing in. It ran absolutely fine on the stock tune on Thursday and I've thought about flashing it back to stock but I don't want to do that just to have to do a crank relearn anyway.
Any help would be appreciated!
Thanks,
Mods are as follows
MAK cat deletes
MRT H-pipe
Thanks,
