Oil oil oil
Christang.GT
Atlanta GA
Cristian
2015 Mustang GT premium pp, FBO CJ/Cams combo, E85
Hello all,
I have a all motor build DAILY cams/ported CJ built valve train 8500 rpm Gen 2 what oil do you guy recommend or prefer I’m currently running amsoil 5w-20 but I want to know what other you guys would recommend because I am at 140k miles now
NoVaGT
Northern Virginia
2019 PP1 GT Kona
You have 140,000 miles on the car, and now you're asking what oil to run?
I'd suggest sticking with whatever oil has gotten your engine to 140,000 miles. That's a pretty safe bet.
1 old racer
Fontana CA
Will
please tell what you are using. that stuff works!!!
Christang.GT
Christang.GT
Atlanta GA
Cristian
True but I don't know I always want to stay all motor for the sake of relability, I am porting my heads and throwning in 13;1 pistons for a all out NA build and wanted to get another option I have simply been running amsoil 5w-20 change it maybe every 5k miles or when the car says to honestly
blind*guardian
Reseda, CA
2019 Mustang GT
Stick with what you’re doing, but 5w-30 seems to be the way to go nowadays since Ford officially switched to it in 2021.
Shifting_Gears
South Florida
Just to be clear - you've been running a stock bottom end to 8500 RPM and it has 140k?
That's solid. Mind sharing if you've had any major issues in that mileage?
As far as oil - 5w20 or 5w30, either one.. brand is user preference but most here back Pennzoil Platinum or Ultra Platinum.
Christang.GT
Christang.GT
Atlanta GA
Cristian
Yup all stock internals. When I did the cams I threw in better valve springs along with the stock valves to hold up to it, I also did OPG's and replaced the entire valve train with new components and did GT350 timing chains that was at 100k miles or so. Other than that I have not touched the internals and issues, before this I was "FBO" 18 mani, all that and had a PCM go bad which caused one of my coil packs to constatnly be fired and melted it, for that I had to go to ford luckily I have a connect in one of my local dealers and I got a used PCM from ebay and they reprogrammed it to my car and overlooked all the mods and previous tune and that's it, other than that it has been 100% reliable, and it's my daily.
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
Penn Plat, Mobile 1, Full Syn Edge, 5w-30. Pick your poison they are all good.
Ebm
North Carolina
Guy
'14 GT
Yeah, I'm with everyone else... You don't need advice about oil at 140k miles. Keep doing what you're doing.
Whitewalkers550
Fort worth
2017 mustang gt premium, 1973 mustang conv.
amsoil is definitely good stuff ran it in all my race bikes and had way less issues after switching to it ill say that and i tore the motor down and rebuilt them every season
