Official RTR Tech 7 Install Thread!
Nodster
UK
James
Thank you! :)
69boss
Washington
Kasey
2017 GT mustang Premium
Got some new RTR 19x10.5" +45mm Tech 5 wheels for Christmas. I'm assuming I need at least a 15mm spacer up front to clear all the brake and suspension parts. Is this the proper spacer size to run? Is it better to go with ARP studs and a slip on spacer or OEM studs and a bolt on spacer?
RTR077
Denver, NC
James
2021 Mustang GT RTR Spec 1
Just throwing in a pic of these wheels lowered on RTR springs. 275/30/20 all around
Nodster
UK
James
Will I be OK lowering on the 20" RTR staggered wheels? I was looking at the Steeda minimum drop springs (0.5"). But then I also quite liked the look of the eibach pro kit springs ~1".
@RTR077 what drop are the RTR springs you have in your pic?
Thanks.
RTR077
Denver, NC
James
Thanks.
That would be Front Drop - 1.1” Rear Drop - 0.8”
Eric5.0
Omaha
Eric
2015 Mustang GT
That's the route I would go. I currently run an 11 up front with extended studs and a 25 mil spacer.
Handles like a dream.
What is the thickest spacer I can run on the Tech 7 wheels without modifying the hubs/studs? Thank you.
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
Not too sure. I would bust out the pen and paper and get your math on
Ruven0119
Georgia
Ruven
2021 Mustang Gt
Anyone running a staggered setup with 19x9.5 front and 19x10.5 rear?
Ruven0119
Georgia
Ruven
2021 Mustang Gt
Ordered the 19x10.5 for the rear today! Still patiently waiting for the 19x9.5s to be back in stock.
Also, Thanks Alex for the discount code!!
Sup bro, did you end up getting the 9.5s for front? If so what size tires are you running?
Nodster
UK
James
So just a sanity check, thwse will be my first set of aftermarket wheels ever. Do you torque the spline nuts up to the same torque as standard? I'm imagining so? Thanks.
S550_Matt
Miami, FL
2015 Mustang Premium PP GT
I would torque mine to 70lbs when i first got wheels. Now i just let the ugga dugga machine take care of it.
