Non rhythmically fast ticking when driving only
jp1234
USA, GA
joe
2015 mustang gt premium
Hey I'm having a weird noise with my 2015 mustang gt, any time I accelerate I get a weird fast pace but non rhythmically ticking coming from what sounds like underneath driver side of the car, I can mostly hear it when I'm next to a wall or another car at a light pulling away. Anyone else having this issue?
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I believe you speaking of the BBQ tick. LOL Yeah mine does it and so does 99% of others. Search BBQ tick and you will be flooded by vast information and some angry discussions on this subject.
jp1234
USA, GA
joe
Alright I will, Ive read about it before I was under impression it was a thing that happened at idle and just random ticking every now and then
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
It normally does it at certain RPM range. Its a little random ticks its not always consistent. Usually peaks at around 2K rpm then goes away at higher rpm.
jp1234
USA, GA
joe
Ah okay gotcha I think you may be right after looking into it further
Aless_andro00
Milan
Alessandro
2017 Ford Mustang
Begin by looking closely at the exhaust system under your car. Check for any holes, breaks, or any kind of damage, especially near the front part of the exhaust and the pipes located under the driver's side. Also, make sure to check if any of the metal guards around the exhaust, known as heat shields, are loose or broken.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Yes Exhaust leaks can cause a tick. BUT due to how common the BBW tick is in the coyote most likely that's what he is getting based on the way he described it. Usually exhaust tick gets worse with rpm and stays during idle if I am not mistaken.
jp1234
USA, GA
joe
I can take a look see if I see anything under there this weekend
