New Whipple Build
Pws6
Usa
2019 Mustang GT
….while turning to boost, yes. Why not upgrade a potential weak point if you plan to introduce a big jump in power. They do break (as we have read about over the years), so why not mitigate that possible risk. Cheap insurance.
I have 64k boosted miles on my Gen 1 engine. Maybe I would have been fine without the upgrade, or maybe not.
They do not break on 2019+ cars. You can not find an example
Kobi Addiction
Houston, TX
2017 Ford Mustang GT350
This is fair. I do remember them being upgraded by FoMoCo on 2019+ across the platform.
robvas
MI
2011 GT
My boosted gen 1 has similar miles and it's fine. It's way, way overblown.
It's a lot of money you could put towards something else (most people are paying labor to have them put in)
WalkRB8
Louisiana
Monty
2019 Mustang Roush Stage 3
I have a new build. 23 GT Auto
Whipple Gen 6
Kooks LTH with green cats
In tank fuel pump upgrade
Borla x-pipe and valved cat back
Full Steeda suspension. The works.
Velgen VF-9 Wheels 20x10.5-295 fronts. 20x11 rears -305
Nitto 555R
Tuned by StangHi in Dallas,TX
720 wheel on 93
Whipple Bullitt
Alberta
Vern
2019 Bullit, 2013 Roush F150
Do the kit. Add a resonator to get that sweet sound and a driveshaft loop just in case. Did a full build on my 19 Bullitt, just doing what I listed to my 22 Mach1 and don’t anticipate any problems. Tire wise, wrap your rims in the widest rubber they’ll take. I’m liking 305-315 setups.
JustSomeGuy
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
If this is a street driven car only, slap the kit on and be done. Traction will be limited, so you won't really break any driveline parts. Just stay off the rev limiter since it's a stick car and you'll be fine with stock OPGs.
If you want any traction at all, drag radials are a must. Second gear will still be a struggle, but third gear should be pretty usable.
It’s a street car and just a toy, most of my driving is shenanigans not roll racing or anything where traction will make or break me. I hate the look of radials. I have a square setup and am willing to go to staggered if it makes a difference?
JustSomeGuy
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
You live in the world of 7% drivetrain loss?
They have a 675hp dyno on their site on 93
I would expect the loss to be reduced with carbon fiber driveshaft and rims that weigh 1/4 of what the stock ones did, I didn’t expect the loss to be 100hp…
JustSomeGuy
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
Usual suspects….
OPG + Crank Sprocket
Oversized Whipple Heat Exchanger
3-Pass Radiator (not a must, but safe)
Aftermarket Clutch w/SS Clutch Line (I have McLeod RXTHD1200)
New Throwout bearing / Slave Cylinder
Tires (I run Nitto 555RII’s)
….suspension pieces to help with the additional power, but that’s all extra.
Sounds good thank you. Every piece of my suspension is already done, I decided to build the car up before I put the SC on.
robvas
MI
2011 GT
Where do you get wheels that weigh 1/4 of the stock ones?
Carbon shaft and light wheels might be worth 15hp on the dyno...tops
JustSomeGuy
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
It was an exaggeration, kind of like when you said a 50hp loss was 7%….
All of my experience with motors and dynos and anything at all is with motorcycles, I am new to building cars. The loss on a motorcycle from crank to wheel isn’t 100hp. Sorry for my ignorance.
flyleclair
Bath, Pa
2016 Ford Mustang GT PP
My installer suggested these items since it was all apart.
Mustang Boundary Crank Gear Sprocket & Oil Pump Gear Kit
Main Force Performance / MFP Coyote Whipple Crank Support
robvas
MI
2011 GT
50 is 7% of 750 though
A modern Mustang is going to see about 15% drivetrain loss. So 112hp on a 750hp car
Factory Mustang wheel might be 30-32lbs, a good after market wheel will be about 10lb lighter
Carbon or aluminum driveshaft is about 15lbs lighter than stock
JustSomeGuy
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
My understanding of the weight loss is with rims and driveshaft the weight is more significant because it’s reciprocating mass that takes horsepower to turn. A couple pounds is more significant than just a couple pounds taken off say the exhaust system. Again, coming from motorcycles.
robvas
MI
2011 GT
Same with cars
