New Battery = Low battery so no AC!
Shadow277
Arizona
2016 Mustang GT 2012 Corolla
I got my battery replaced on last Wednesday. Now I am receiving the same message: battery low. system recharging and "low battery, some features may be disabled."
I am thinking about disconnecting the battery over night to reset it. I had the car tested to and all the computers read normal, as per Firestone.
Anything else I should do? Not having AC when it is 112F outside is not cool.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
There is a battery life monitor that usually resets after sitting for 8 hours with no activity. Might want to look into doing a reset of that with Forscan.
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
Shadow277
Arizona
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Forscan isn’t needed as the reset can be done manually following these steps:
1. Turn on accessory switch but don’t start the engine
2. Within 10 seconds flash the high-beams 5 times then press the brake pedal 3 times
3. The battery indicator will flash 3 times and then come on solid
4. Turn off the car
5. Lock the car with your remote and let it sit for at least 8 hours
You should have no problems the next time you use the car.
Farkel
Marc
Had no idea it was called BMS. Thank you kind sir.
Yer welcome. Can't promise those steps will resolve your issue, but they should be done when the battery is replaced.
Shadow277
Arizona
Unfortunately both did not work. Battery light never flickered and disconnecting the battery for 8 hours did not work.
Considering my mechanic said it is electrically fine, I am out of ideas other than asking for another battery.
Shadow277
Arizona
What does the voltage read on the dash menu?
What is the date stamp on the battery?
What is the voltage of the battery after letting it sit for more than 2 hours?
I have had a junk brand new battery before so it not to uncommon.
I am the office so I have no tools to check. Might check on my lunch break. I am thinking about trying the BMS again. Maybe I did something wrong. If not, then I'll check what you asked and will probably have to take it back to Firestone.
Farkel
Marc
By all means, try the BMS reset again. Follow the directions carefully. Also, disconnecting the battery will clear the keep-alive memory (KAM), but only the 8-hour sleep (with the battery connected) will allow the system to determine the battery's state of charge.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If you don't have forscan take it to a dealer and have them reset the BMS.
K4fxd
NKY
Forscan is free, just need a 50 dollar dongle.....
The Demon
Brett
2022 Mach 1 N5809
Is resetting the BMS because his is a 2016? I changed my battery on 6/4 and did nothing. No issues at all with the car. Everything works well and the voltage is 14.4 when driving. I have never tested the resting voltage.
Farkel
Marc
BMS reset resets the days-in-service parameter, which is one of the things the charging system software looks at to determine when and how much to charge the battery. AFAIK, this applies to all the 6G Mustangs.
Jaymar
Portland, OR
Jaymar
It usually resets itself and manages everything in the background but like all gadgets, it is prone to taking a huge dump sometimes and goes haywire. There is a thread here where some have had to disable it completely. All this monitoring and the damn battery still only lasts 3 years or so.
