Negative terminal battery options..
SSG 5.0
2017 Mustang GT
I just got done talking a Ford parts rep and I just can’t get a terminal battery. Ford apparently sells them as a whole wiring harness etc… asking price is $6xx lol. I know I can unbolt the negative terminal from the cable and change it that way.
What site or negative terminal battery y’all recommend for a FI car? Thanks a bunch.
NTXChris
North Texas
2019 PP1 GT
You're just wanting to replace the terminal clamp on the negative cable? Why would you need something for a FI car? Unless you are placing a lot of electrical load on the battery, the factory style terminal clamp will be fine.
Mine was corroded to the negative terminal of the battery; so when I replaced the battery, I got a new one from Amazon:
https://a.co/d/18ghgvC
Same exact part as as the factory one.
boB
boB
2019 GT PP1
Waytek has some that may work.
SSG 5.0
SSG 5.0
2017 Mustang GT
Thanks guys. I’ll take a look tomorrow. It’s corroded and I just replaced the battery last week.
SheepDog
Colorado
Dax
One thing you need to look out for: if there is corrosion on the cable end, there may also be corrosion creeping up the cable itself. It spreads like an infection. Once you unbolt the negative cable end, peel back some of the insulation and make sure the corrosion isn't working its way up the cable. If so, you may have to cut the ring terminal off, and re-crimp a new one on. If the corrosion has spread more than a couple inches up the cable, you would need to replace the whole thing
https://www.amazon.com/EDS-926-879-...5&psc=1&mcid=19ffff3d0cc834118f734a10de7bfef8
SSG 5.0
SSG 5.0
2017 Mustang GT
Appreciate the extra advice sir. Better than getting corrected for sure. Like always, you’re giving some great advice.
