SBR70.3
- Mar 13, 2017
- Edmond, OK
- Chris
- 2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
I’m installing Steeda lateral and tension links this weekend.
Tension links went in without issue. The lateral links….not so much.
Once I got everything installed, I put the wheels on so I could clock the bushings. I immediately noticed a shit ton (~20 degrees) of toe out. WTF. I looked at everything and the only culprit I could find is the ball joint post on the lateral links are not fully going into the knuckle. There is approximately 1/2” of exposure on the ball joint post. I removed and reinstalled them and they do not fully seat into the knuckle. Is this normal for the Steeda lateral links? Could this be causing my toe out? Other suggestions?
I emailed Steeda but they won’t respond until tomorrow. I was hoping to finish this today.
Thank you for any positive suggestions you may have.
