Need help deciding which procharger
NC85
CA
Missing
Ive been 5.72 at 120 on a stock gen2 engine with a p1sc. So your goal is easily obtained.
That's what I like to hear! How many PSI did it take you to run .70s?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Who knows. I dont pay attention to boost numbers as its an arbitrary number.
Jay-rod427
Kansas
2016 GT C/S
Mine supposedly had the helical gears and it was far from as quiet as I expected it to be. DAMN sure 100% not stealth at all.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
80 fox is this true:
The slinger gear, is used to transfer or centrifuge oil up is a large part of the gear noise associated with Procharger’s . Helical gears have a smoother engagement which comes at the expense of additional axial load on the bearings..
sloride
ohio
2016 GT
I’m running a D1x with a 4.5 pulley seeing 13 psi at 8k and 820whp. On e85
I’m on P1X and 13psi at 7500 and E85 4.25 pulley. No idea on horsepower but curious if power levels would be in the same ballpark
FastCarFanBoy
2013 GB GT
Yes, that is true. Helical gears produce side loads on the gears that straight cut gears do not. Helical gears are also supposed to be stronger as they spread the force out more across the surface of the gear however considering that Procharger does not offer helical gears on the big race focused superchargers I don't think gear strength of the straight cut gears is a factor in this application.
Dominant1
Dr Frankenstang
Ok thanks...
Dominant1
Dr Frankenstang
Hey guys when i drop down to a 4:38 pulley from a 4.88 on my d1x, is a tune update required?
Chummel
Tulsa, Ok
2015 Mustang GT PP
Not necessarily, you will want to log it though and make sure everything looks good.
Jay-rod427
Kansas
2016 GT C/S
I'd agree. We've blown up plenty of blowers and it's never the transmission. Impeller, shaft, and bearing are always the fallout.
Barrel
Hoonigan
Cars and Trucks
Informative video for helical vs straight gut gears.
beefcake
Bethel
2018 Ford Mustang
p1x is more than enough on an 18 with di, and 12:1 compression. the 18 and up are very boost friendly, they just wanna make power,
feel free to give me a ring with any questions on any blower setups, it's our speciality
Terry "Beefcake" Reeves
Office - 855-TBR-RACE - Cell 513-478-1965
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
