Educate me. I need help deciding between these two products.
hockeydave55
South Bay, L.A., CA
22 Mach1, 69 Fiat 500F, 23 MachE, 13 Focus, 10 GT
vinny89gt
VA
LaFlamaBlanca
2023 Iconic Silver GT PP
Agreed on the one with the breather. It connects the clean and dirty sides with check valves and helps eliminate crank case pressure under boost.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
Another bonus with the breather is that none of the crank case vapors are pulled back into the intake stream. Absolutely no chance of blow-by fouling the intake. I would expect to it to be very important to ensure that the catch can and breather filter are emptied regularly and not clogged. Am I understanding this correctly?
robvas
MI
2011 GT
You can also spend 1/10th the $ and just put a pair of valve cover breathers on
beefcake
Bethel
2018 Ford Mustang
We like the breather style as others have said let us know if you need any help give us a shout or shoot us a dm
Nameless83
Central Texas
2017 Mustang Gt bOoStEd
I'm Boosted on a Whipple and I have a passenger side catch can installed. Should I also run the breather setup as well?
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
I switched to just breathers on my boosted set up.
SnowFox
Mn
Grabber
Breathers? As in two? One on each side?
Yep just two of those basic AutoZone breathers. I've tried a few variants of catch cans. And they all work well. Nothing against any type of set up.
some people have issues with saturating the breathers with oil and then it subsequently sprays oil in the engine bay. It's never happened to me. I can see it happening if you constantly do hard pulls.
i clean them every month or so.
robvas
MI
2011 GT
I haven't seen any oil in mine
I can smell it a little bit after a pull
I want to wrap a paper towel around them to see what it picks up
Nameless83
Central Texas
ok thanks. I’ll probably stay with the catch can for the time being and check it at the end of each driving day.
