Need help deciding which procharger
AZ18yote
Arizona
Bryan
Yes a straight cut procharger sounds like it’s grinding up small pebbles mixed with a 350 chevy Taft has a squeaky alternator belt.
Sounds awesome imo
Helical gear option gets rid of that sound if interested. Then just sounds like a jet :sunglasses:
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I'm a speed guy so 142mph in the 1/4 and 176mph in the 1/2. I wanted to to get over 180 in the half mile and just couldn't get there. Was stuck in the low-mid 170s.
Sounds like you have some room left in the d1sc. Ive been 150 in the 1/4 with stock engine and P1SC.
Barrel
Hoonigan
Cars and Trucks
I was at max blower speed so I'll never know. Both of those are also on 20" wheels - because reasons.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
If you were at max impeller speed, you have other areas to optimize.
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
All the noise!!
Yea that is the sound I remember, so I'm definitely thinking I don't want a hang on unit.
Do not want everybody to know my car isn't stock, thinking Whipple or Roush stage one with no exhaust modifications, easy 550hp to tire. What more could you need for the public highway?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Need and want is to totally different things....
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Def build what you want. S550 world can accommodate sleeper or a bunch of racket!
JPSTANG
MN
Joe
2017 Mustang GT
Sooo here we go, I have a D1X and i can tell you it does suffer a "little" down low. Now i did the D1X cause i did know that later i was going to turn it up with a built motor (maybe this winter) and just have fun with it in the short term. It hits really good at the top rpm and is not as responsive at lower RPM's i think, but for what it's worth to do it now it was the "right choice for me". As said if you have no goal for a built motor to get the max out of it, stick with the P1-X stg 2 (you wont be dissapointed). You can still get huge numbers with supporting mods and have a lot of fun with it. I am surprised no one here has mentioned spinning it faster and a wastegate on the D for lower punch... LOL let the discussion begin...
Jordanfmeyer
Manhattan, KS
Jordan
2017 Shelby gt350
Sooo here we go, I have a D1X and i can tell you it does suffer a little down low. Now i did the D1X cause i did know that later i was going to turn it up with a built motor (maybe this winter) and just have fun with it in the short term. It hits really good at the top rpm and is not as responsive at lower RPM's, but for what it's worth to do it now it was the "right choice for me". As said if you have no goal for a built motor to get the max out of it, stick with the P1-X stg 2 (you wont be dissapointed). You can still get huge numbers with supporting mods and have a lot of fun with it. I am surprised no one here has mentioned spinning it faster and a wastegate on the D for lower punch... LOL let the discussion begin...
Putting a wastegate on the P1X stage two sounds interesting to me. Does anyone here have that done?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Wastegated setup is less than ideal. The proper head unit for the setup will yeild best results.
ahl395
Allan
I have a wastegated P1X. My blower is maxed out now so the wastegate is just closed all the time, but previously I ran it with a boost controller and at 12psi and 15psi with the gate. It improved midrange a ton. Boost builds instantly instead of waiting for 4k rpms while being able to adjust your boost level on the fly. The downside is increased IATs, but it's still manageable and was worth it for me.
Why do that? Just run it maxed out and call it a day.
Not everyone wants to or is able to run the blower at max boost, the wastegate will let you improve your midrange while still running the amount of boost you want. But yeah if you can max out the blower, the wastegate is useless.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
If one does not want to run with the unit maxed out, the head unit is too big for the application. Centrifugal blowers are designed to run at or near max impeller speed. Increased IAT, added cost, added complexity, tuning compromises and rapid loading / unloading of the blower are additional downsides to a gated setup. If one wishes to have more low end pep, PD blowers would be perfect for that individual.
