nrm101
Having a bit of a challenge in the reinstall of the Transmission, i do have a decent transmission jack (NOW) after i get everything lined up and level, the last push i just can't get the "Pins" at the top to seat into the transmission, now the bolts all around line up pretty must perfect i can hand thread all of them, so should i just suck the last 1/4 inch with the bolts or is this signaling maybe the input shaft isn't seated right?
Is there any way to verify the shaft is in and good, should i remove the bottom panel plastic and spin the motor from the crank?
Thanks for any help..
