My 0-60 time is not there.
Crowd.Slayer
Las Vegas, NV
2017 Mustang GT Oxford White
Hey guys. I'm not sure if I'm doing the right prep, launching wrong or a combination of both. I have a 2017 auto. Recently I added upgraded wheels/tires. Originally I was on squared 255's all season. Now I'm on a staggered setup of Nitto 555 G2's with 255 up front and 305 in the back. My 0-60 time has not changed and is far off from the claimed 4.4/4.5 as stated. I'm hitting 5.7 seconds with even some grip issues from a dig even with the 305's. Is there something I'm doing wrong? I am testing in 78 degree weather. Not too cold, not too hot. Tires were warmed up after a 25 minute drive and... almost 6 seconds? I'll take credit if i'm an idiot and doing something wrong. Now, this is from a stand still and i'm not raising RPM's before I launch because I was under the impression on stock suspension/driveshaft it's not the best to do over 2k. Am I misinformed?
Please drop some knowledge on me because this doesn't seem right.
This is street, not track times. I'm sure that makes a difference but just wanted to make sure if i am doing something wrong, I would like to correct it.
Only mods done are Roush intake (no tune), MBRP race exhaust with H-pipe and Eibach sportlines.
Crowd.Slayer
Crowd.Slayer
Las Vegas, NV
Need a little more info. Do you have TC off? Does your car have drag mode? Are you on a clean, level road? Also, to get the "best" numbers you really need to be on a prepped strip, and beat on the car like you hate it. I'm talking stupid high RPM launch. As much as you can do without just spinning.
TC is on, though the light does not engage on launch. My car is a 2017 base model and does not have drag mode as far as I am aware, just the Sport Mode which I have it in. Streets are about as level/decent as you could ask for aside from a brand new paved road. Considering this is my daily, I try not to beat on her too much. Would brake launching lower the times significantly?
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Its because your TC is on. It pulls engine timing to reduce wheel spin which means you make no power until higher gears.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Beat me to it. Even if the light isn't on, it's still working in the background.
Yeah, honestly the light pretty much never comes on for me unless it's wet out and both rear wheels are spinning like crazy, lol. Another "idiot light" that is way too conservative. Especially since I can feel the rear tires slipping as I mat it in 2nd, and the car bogging. As soon as I slam it in third it pulls way harder. I need new tires.
Crowd.Slayer
Crowd.Slayer
Las Vegas, NV
Alright. Interesting. I did 3 pulls, all different.
First was AdvanceTrac off and brought the RPM's to about 1500 and let go. Spin city. Dumb but fun.
Second, same setup but with idle rpm's. Less spin but still spun about halfway through first. No good. Funny thing though, that spin through half of first still put me at exactly at 5.7 again. Which tells me it's traction if i'm pulling the same time with TC on and no spin, compared to TC off and half of first going to waste.
Third was AdvanceTrac on and TC 'off' and that netted the same time with spin. 5.7 again.
I guess I'm going to chalk it up to tires are the issue, need something stickier next time i change them out.
So either I run 5.7 with TC on or I run 5.7 with TC off and spin through half of first.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Yeah, that's just telling you that you need better (or more) tire. You can also try airing your rears down to like 28PSI or even a bit lower.
hlfbkd420
SW 'Merica
Bilbo Hicks
2015 KIA Sorento SXL
Get a dragy instead of using the track app.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Do you have stiffening suspension mods or are you lowered? Sounds to be like you’re getting hardly any weight transfer. A stock 6R80 car with any all season/summer tires will pull 4.6-5.2 0-60.
Crowd.Slayer
Crowd.Slayer
Las Vegas, NV
I'm lowered with Eibach sportline springs and that's it for suspension. I will look into some drag radials, they seem like they will make all the difference.
Cory S
Bradford, NH
Cory
DR’s will help, but you’ll still find it hard to best under 4.8 with that tight suspension setup.
cahouston
Houston
2019 Mustang GT A10 Premium
Many times, manufacturer claimed 0-60 times are produced on a track of some sort. It will be hard to find a road which will allow the same. To get the best time, you will need to feather the throttle a bit before too much traction loss occurs including launch. Don't just mash the gas off the get. Ease in a bit to try to get traction with a 1200 or so rpm launch. My best times (still under claimed 0-60 times from Ford) were with adv track off and feathering throttle at times where I knew traction loss would occur.
Crowd.Slayer
Crowd.Slayer
Las Vegas, NV
So is a looser suspension setup ideal then for digs? It being too tight, what makes it a drawback? Or rather how does it make it a drawback?
Crowd.Slayer
Crowd.Slayer
Las Vegas, NV
Thank you! I was actually wondering about that exact technique of feathering into it instead of mashing the throttle to gain grip. I suppose it will vary per car/setup and I will have to mess with it to find that sweet spot.
Cory S
Bradford, NH
Cory
It will handle better being lowered with stiffer springs, but you’ll reduce weight transfer to the rear tires. More noticeable at slower speeds.
