Mud Flaps - anybody use them ?
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
https://zl1addons.com/products/copy...mustang-2015-2017-6th-gen?variant=30386015617
The website uses the same pictures for the standard and deluxe version, but the description says that the deluxe version is made from a thicker and more durable material, and that the edges are more rounded.
I have the standard version. They are very slim. But I like them. They are practically invisible, which is a lot of the reason for my purchase. And compared to the AM flaps, they are half the price. :thumbsup:
They are nice, but not sure if that are worth double the price of the ZL1 flaps. For me, you are paying a lot more money for a lillte horsey logo. :shrug:
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
69mach1-395
central nm, usa
2016 RR GT/CS
Dkar26
MaxPower
EARTH
Jim
2017 GT premium
sub'd for CPC pics
mustank
APO
2016 mustang gt
anybody pick up the RPI design mud flaps? I am curious because it looks like the rears mount different then the other "block" methods.
Stripes
Greater Toronto Area
15GT 401a + Roush AB, MRT H-Pipe
just received my ZL1Addons fronts and rears. I feel like an idiot, because it took me a solid 3 hours to get the fronts on. I had everything set up, I just couldn't get those damn plastic retaining clips in, I was surprised how much excessive force I needed to get them to click in properly.
I'm planning to install the rears tomorrow. I'm going to install the blocks directly onto the flaps, then install the whole assembly onto the car. Seems much easier than actually removing the rear wheels as per the instructions.
On a different note, I'm actually surprised how well the double-sided tape adheres.
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
Planning on doing mine soon so looking fwd to how that works for you Stripes.
Souldriver
NY
2016 - Guard GT Prem. PP
I will be needing some, surprised how just 3 months with the more offset wheels really dotted tue sides in front of the back wheels. I wonder why its in front of the rear wheels but i guess the fronts and slinging it most.
POJ 1
Auckland New Zealand
Phil
2019 Bullitt build no.301
Had the same problem and my car painter told me that where the body flares out to create the rear wheel arch, this chang of shape interrupts the air flow (and grit etc) along the body coming off the front tyres.
As a result the grit hits the body low down between the rear of the door and the front of the rear wheel arch causing the gravel rash.
Just got my RPI mudflaps put on the front 2 weeks ago so hopefully issue minimised. I didn't put the rear pair on at this stage as all the problem seems to come off the front (especially when the wheels are turning) according to my expert.
Aerodynamics!
you just can't beat it!
Bushranger
Australia, NSW Northern Rivers
Peter
Ruby Red GT auto fastback
Well if you want to, you can clear wrap that particular area. I did and I'm a novice. It is the easiest part of the car to wrap as it is relatively flat. Just cut an edge that follows the door gap down to the bottom of the rocker. It inspired me to clear wrap other panels with not so spectacular results. Trust me it IS wrapped. I need to tidy up the top right corner a bit.
mustank
APO
2016 mustang gt
any particular reason you say the RPI do nothing? Are they less effective than the other options, or are all of them really just ineffective?
RubyRed15
Ok, so it's blue.
CO
Ecoboost Premium PP
I can't speak for any other design. I had the RPIs and just got done repairing another hundred thousand stone chips since I installed them.
