The shifting on the T3650-equipped V8 cars between 2005 and 2010 probably saw their biggest improvement in 2008. I had a 2007 GT and noticed an improvement in the positive feel in my 2010. In both cases, however, many people liked to switch out to another shifter to shorten the throws and get a more positive feel. The GT power levels at the time didn't expose the twisting of the shifter mechanism, which was the cause of missed shifts that was more prominent in the 2011 V8s.
In 2011, what many experienced was not only the missed shifts and difficulty getting into gear but less positive engagement because of the rubber "bushing" to damp out noise and vibration. Of course, there was a new transmission now too - the MT-82. As Grimace mentions, he has a good experience because he modified his configuration. People switched out the entire mechanism or got a bracket to better hold the shifter in place. I've felt the shifter in the 2015 now, and I can safely say it is improved over the earlier mechanism for the 4.6L V8 cars. I suspect compared to stock 5.0L V8 cars, there should be a noticeable change for the good.
Before anyone goes ripping it out, I suggest trying it. The teltale tests, I think, are as follows -
1) ease of finding each gate
2) not having difficulty engaging the shifter when the engine RPMs are on the high end
3) the degree of mechanical feel (does it "click"?) when going into each gate
Based on my short time with it back in August, I think there was solid engineering such that an aftermarket shifter really might only bring you a shorter throw, if that's your thing. Your experience may vary, depending on how much you like to slam the shifter into gear.
PS - The MT-82 got a reputation when there were some early troubles with noise levels, the clutch return spring that sometimes caused the pedals to sit on the floor when trying to shift near engine redline, and the "squshiness" from the shifter mechanism torquing and the bushing being so rubbery. I think those times are past us - at least I believe they will be, based on the improvements that have been mentioned.
That is what I read to, but after driving for 800 miles or so I'm anxious to see what the after market comes out with. I'm wondering a bit if there is a quality control thing & some of the shifters are better than others. Mine is just ok otherwise and the 4 - 5 journey is long and just meh feeling.So just about all reviews rave about the transmission and its short throws. I'm thinking Ford did a good job of tweeking the tranny for the 2015. Did the S197 ever get such high praise?
Thanks for the nice write upThe shifting on the T3650-equipped V8 cars between 2005 and 2010 probably saw their biggest improvement in 2008. I had a 2007 GT and noticed an improvement in the positive feel in my 2010. In both cases, however, many people liked to switch out to another shifter to shorten the throws and get a more positive feel. The GT power levels at the time didn't expose the twisting of the shifter mechanism, which was the cause of missed shifts that was more prominent in the 2011 V8s.
