stangman638
So far 1500 miles on mine oil level still perfect.the only downer with a GT350 is the oil issues. Consuming 1 qt/ 1000 miles is unacceptable.
Well it also sorts feels like a moving target as well, but I was considering do that mod but frankly it doesn't bother me enough to make the mod, been driving stick for almost 20 years now.Clutch assist spring needs to be removed or replaced with the steeda one.
Cheap and easy, and makes it feel like a real clutch. 10 mins later and all is better.Well it also sorts feels like a moving target as well, but I was considering do that mod but frankly it doesn't bother me enough to make the mod, been driving stick for almost 20 years now.
I wouldn't call it two driveshafts, it's just a two piece driveshaft with a center support. I don't really know why that is, but that's what they did for some reason. Maybe it helps with NVH?I'm also happier with my MT-82 than previous Tremecs I've owned (2 Corvettes and 1 GTO). The one on the last Corvette was actually defective right out of the box (a bad 2nd gear synchro). It's only possible shortcoming compared to the Tremecs is its ability to take abuse, but since that won't be an issue under my ownership, I don't have any issues with it .
Hey gang, as a side question, somebody mentioned our PP1 cars have TWO driveshafts. Why the heck is that, with such a short distance??? I thought PP1 cars had just 1 piece. Even seems more expensive, having to add a brace point, etc. Curious why. Thx.
Two-piece driveshafts are used to keep the driveshaft from hitting its resonant speed. Crudely, this is a 'stiffness' thing, where the two shorter shaft pieces would be stiffer than a full-length shaft of comparable strength. Bad things happen if a driveshaft hits a resonance.Hey gang, as a side question, somebody mentioned our PP1 cars have TWO driveshafts. Why the heck is that, with such a short distance??? I thought PP1 cars had just 1 piece. Even seems more expensive, having to add a brace point, etc. Curious why. Thx.
Check out Car and Driver's report on the car:So far 1500 miles on mine oil level still perfect.
All the best.Ford released a supplement to the owner's manual stating that the engine might consume a quart every 500 miles under severe use. "Severe use" pretty accurately sums up our treatment of just about any car, but particularly one with an 8250-rpm redline. And we were lucky; internet forums are rife with horror stories of Shelbys consuming far more.
^^^^the only downer with a GT350 is the oil issues. Consuming 1 qt/ 1000 miles is unacceptable.
^^^^How many beers did you knock down while typing all that??
1. Your Mach 1, will have the same 5.0 as the GT. The 350 is hand assembled by one person and is a 5.2L with superior internals that sounds as good as it can rev. My 350 doesn't make ticking noises and all sorts of chirps both my 5.0's did. This alone is worth all the reason to buy this over any 5.0 The gen 3 is a 9k engine, the 5.2 is a 20k dollar engine.
2. The suspension and handling will still be better in a 350, not that it matters much because 99% will not bring it to a track. It most likely will sit in the garage.
3. The 350 says Shelby on it, the badge alone adds +23HP ... J/K!! It will hold its value better imo, so resale value I give to the 350.
All said and done, the 350 is still one of the best mustangs built to date.
The mach 1 is something that the GT should have been. It's very nice, but its not 55k+ plus nice.
I will take my gas guzzling flat plane crank that ford may or may not have gotten right over the 5.0. and besides still plenty of new 2019 2020 on dealer lots around the country if your willing to look, you can definitely get a good deal.
I think most of them don't consume oil. Mine never did, whether it was on track or on the street. 33,000 trouble free miles. I wish I still owned it.the only downer with a GT350 is the oil issues. Consuming 1 qt/ 1000 miles is unacceptable.
^^^I hope I don't jinx myself, but I really like the MT82D4 in the 2020 Ford Mustang GT. Only the ratios are a downer, the shifter and smoothness of the tranny I am enjoying immensely.
