More false knock
Tommy V
Brookly park Md
Tommy
Am I correct in assuming False knock other than robbing power is otherwise harmless?
Yea that is true until u have the tuner turn the sensitivity down on the ks because your tired of chasing false knock and then something happens wheir real knock comes into play and the wipe a piston or rod out.Its a real fine line that alot of us walk,but i rather have my ks working correctly and then if their is absolutley no way to fix the false knock then maybe turn down the knock sensors.But u better make sure it is 100% false knock!!!!
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
I know its not funny...but I laughed.:lol:
Looks like one member found his.
https://www.facebook.com/jeffrey.scottoddo/videos/10154813766321024/
Yup... that's mine. And I'm still showing slight knock while cruising. I'm thinking it could be because I installed the BMR differential bushing lockout kit matched with my polyurethane motor mounts. It's just causing enough NVH at those RPM's that the knock sensors are going crazy. At least that's what Lind told me could be causing it. I'm on E85 so it pretty much has to be false knock.
Jeff_oddo
Jeff
Mustang GT Premium
false knock is exactly that "false".......put some 100+ octane in it and if your still getting false knock it is truly false knock.....then have your tuner turn down the knock sensitivity and call it a day....i was getting false knock on 116 octane so turned the sensitivity down and the car ran like a champ....anything can cause the false knock, in my most recent case on my 2014 it was because i swapped in a tubular k member and the solid mounts could be felt through the entire car.....turned down the knock sensitivity and all good now....
That's what Jon Lund Jr told me today. After adding my BMR differential bushing lockout kit along with my polyurethane motor mounts the knock sensors are going crazy I think.
Hoover,AL
2015 mustang gt premium 6 speed
This is probably going to be one of my issues, but I noticed I was missing one of the washers that go on my vertical links in the rear (1 missing on driver rear side). Could this be contributing to the knock since it may have room to hit?
Jeff_oddo
Jeff
Mustang GT Premium
Honestly I'm not sure.. but it's worth a shot to add a new washer.
mdnt
Albuquerque
15GT/PP RubyRed
make sure your oil drain line isnt bouncing on anything, mine broke the zips i had it setup on and started to give me random False readings
Jeff_oddo
Jeff
Mustang GT Premium
I went ahead and secured the oil line better to where it won't tap on anything. I also cleaned my MAF sensor and dumped my catch can out. Not sure what else could be causing the false knock besides the added NVH from my BMR differential bushing lockouts and polyurethane motor mounts. The car is on E85...
Hoover,AL
The tuner might turn down the sensitivity just a bit on the sensors. Only reason mine wouldnt do it is because it saw 9*
dubster99
Nor*Cal
2015 Ingot Silver GT PP
There are tons of people running those parts that don't have knock though. Not saying it couldn't be that...every car is different.
Jeff_oddo
Jeff
Mustang GT Premium
Kind of interesting that it happened after I installed the BMR differential lockout bushings. One of these days I'll get around to pulling them off to see if that was the culprit.
dubster99
Nor*Cal
You're making me nervous. I have a set in the box, waiting to install my 3.31 pumpkin.
Slamdcoop0428
SW Florida
2016 Mustang GT Premium auto
I bet its more the poly motor mounts over anything. I commented on your facebook post with my header flanges having a ton of play. Still have to go out and test but i cut the ball and socket out and ised these. $30 fix
Jeff_oddo
Jeff
Mustang GT Premium
Yeah I'm debating putting stock ones back in. Lol
Slamdcoop0428
SW Florida
Hoover,AL
update: Car is till showing knock, but I've noticed that it comes in sometimes when i'm just at partial throttle about 2*. No clue what this could be since the engine would not be torquing over.
