Modifying As-Built Data Guide
RavenEco17
My17 Eco Fun
Gold Coast, Australia
Ford Mustang Ecoboost My17 Sync 3
Line lock track mode codes
Hello everyone, ok so I have the forscan up and running. All reading as expected. I'm now trying to find a current listing of modifying codes for the Ecoboost. Specifically, the line lock that is turned off here in Australia. I would like to turn it back on. ;) If there is a link to the current codes please let me know. I would like to change a few other bits. :D
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Line lock is disabled on all ecoboost on earth :D
Ebm
North Carolina
Guy
'14 GT
If you do changes to your Sync system, what happens the next time the system receives an update from Ford? Say you add Navi. Will that get erased when Ford does an OTA?
papinist
The Italian Pony
Tuscany, Italy
Stefano
The navi mod is only for Sync2, and I don't think it will receive any new updates whatsoever.
jstump2490
Ohio
2015 Mustang GT Premium
Ford does not do OTA updates, at least not on Sync2
rvlyssup
Vag...Gun...Stang-NUT
Palmdale...The High Desert of SoCal.
Rand
Lotsa...
For the folks adding MyColor to their base Mustangs, anyone successfully use a premium cluster off a 2016 or 2017 on their 2015 and vice versa?
Seems the 2016 & 2017 premium cluster has 14 lines of code/data versus 12 lines on the 2015 premium cluster. Not sure what the 2 additional lines are for...along with what will happen (or may be missing) if those extra lines are not in play on a 2016...
Guess I'll be finding out this weekend.
MSMStannyl
Baltimore, MD
2015 Mustang GT Premium - Triple Yellow
I can't give you any details but I recall recently stumbling on a thread about how "easy" it was to enable line lock on an EB. I believe it was a guy who did a Coyote swap into his EB and he turned it on. Unfortunately, I think I recall him saying that he had to take it to the dealer and pay like $300 for them to turn it on. Do a search for his thread. It was something like "Line Lock Easy as 1 2 3" or something like that.
solodogg
Orlando
2015 Mustang Ecoboost
http://www.mustang6g.com/forums/showthread.php?t=67279
It's not possible using this method at this time unless there is a missing step somewhere. I followed his exact directions, and received the same errors that I did when enabling linelock with ForScan. I have also copied ABS controller settings from multiple other S550's that had OEM linelock enabled, and none of those were able to enable the option without error.
I believe there is something tied to the PCM that makes this error out when enabled on an EB or V6, similar to how the speedometer adjustment settings throw a DTC but do not set off a CEL since it's not a serious issue.
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Has anyone seen anything relating to speed/MPH for convertible top operation? I'd love to be able to operate the mechanism at 5-8MPH vs. none, it's super handy when you're rolling up to a redliight to be able to start it moving.
In my S2K, there was two safety mechanisms, 1) speed and 2) e-brake set, and 1 was easily bypassed with a little wiring change, so then you could just engage the brake up a couple of ticks and raise/lower.
Verts get a DIC message, so I thought the logic might be available module config/BCM data.
Figured since it's been close to 3 months since I asked this - and people have done a good bit more research on the available codes - I'd ask this again.
:cheers:
DanMc85
The Source
New England, USA
2014 Ford Fusion Titanium AWD 2.0L
