Modifying As-Built Data Guide
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
If I use a base auto then my performance pack center gauges won't work, and since there is not a performance pack auto base, I used the 50th anniversary that was the closest.
but you could at least compare.
some registers won't be present, and some will have different values.
Since you're dealing with a configuration that doesn't exist you will have to get down to the bit level and see what each tiny change does.
I did the same thing with my '08 F250 XL to enable RKE... something Ford said couldn't be done.
PR78
Maisons-Laffitte, France
Ecoboost - Magnetic Grey
Hello
I found on the internet that these codes may enabled or disabled automatic headlights :
726-09-01 0100 x37x xx may be auto headlights disabled
726-09-01 0100 x38x xx may be auto headlights enabled
726-12-01 0000 000F 4F may be auto headlamps disabled
726-12-01 0001 000C 4D may be auto headlamps enabled
If someone have automatic headlights/headlamps enabled, can you confirm that you have theses codes on your car ?
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Aren't auto headlights standard on all models?
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Hello
Surely you can just turn your knob to off position :shrug:
50Mustang
Virginia
2020 Lincoln Corsair & 1990 Mustang GT. 2019 Mustang GT PP2 (Sold), 2019 Lincoln MKZ (Sold), 2017 Mustang GT PP (Sold), 2009 Civic Si (Sold)
I have a challenge for everyone:
I'm about to do a Sync 3 Swap on my Base GT, however, all the parts I have are coming from a GT350, including the bezel.
Would it be possible to program the toggles the Shelby has for my GT? Hazards and traction control are the most important, but I was wondering if I could get Launch Control working on it. Also, we don't have active exhausts until the 2018, so it would be possible to rewrite that for the steering feel? I honestly don't want to lose that.
Wish I could be more helpful rather than asking for help, but this is what I'm currently facing.
DB83
Granny Shifter
Spain
2017 Mustang GT
So, I've tried loading the Ford GT splash screen and blue colour theme, but it didn't take.
I've used the following settings
APIM
7D0-01-02 0xxx xxxx xxxx
7D0-02-01 xxxx xDxx xxxx
7D0-03-01 xxxx x4xx xxxx
My car is an EU 2017 mustang GT with Sync3 Ver.2.0
Any ideas?
Thanks!
kcc0521
Falls Church VA
Bo
2015 Black GT PP
The the control for the gauges is in the PCM data. Lund turned mine on because i forgot to use a 50th anniversary AS Built. The problem with the 50th anniversary as built data is the all of them are fully loaded and my car din't have many options.
leszek
Kirkland, WA
S550 CO GT PP vert
APIM
Any ideas?
Thanks!
For GT theme you need 2.2 or later. Install the official 2.2 upgrade from Ford owner web site.
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
Hello
I have totally different values at these blocks:
726-09-01: 3146 4136 5075
726-12-01: 0163 0827 6538
:shrug:
DB83
Granny Shifter
Spain
2017 Mustang GT
Apparently if the car came with 2.0, you shouldn't update to 2.2 as it can cause problems.
Any one else confirm that?
Gmacguyver
San Diego
2016 Ecoboost PP
Added drive modes on a Base 2016 performance pack ecoboost. Confirmed codes below:
Base 2016 performance pack eco:
IPC - 720-06-01: 786D 0664 108D
ABS - 760-02-02: 0200 026F
Change to
Premium 2016 performance pack eco:
IPC - 720-06-01: 786D 0664 1895
ABS - 760-02-02: 0200 127F
MakStang
Greece
www.cellentis.uk
Makis
[MENTION=13606]Gmacguyver[/MENTION] what do these codes do exactly? :confused:
thet33
Dallas, TX
2016 Magnetic GT/6MT/3.55
IPC - 726-06-01: 786D 0664 108D
Change to
IPC - 726-06-01: 786D 0664 1895
:thumbsup:
MakStang
Greece
www.cellentis.uk
Makis
I suppose the correct IPC block above is 720-06-01. Blocks that start with 726 are BdyCM.
