Misfiring even after replacing coils
Sadimsosad
Houston
Christian
2015 Mustang gt
2015 Ford Mustang GT. 48,000 miles.
Catless long tube headers and tuned on E85.
Warmed up car and drove 30 seconds before I got a p0351 and p0354 code. Replaced all 8 coils and plugs which were gapped at .030 from the car previously having a Whipple blower on it. New plugs gapped at .050 .
Still have the same codes.
Checked for constant 12v at coil - ok
Checked continuity between coil and PCM - ok
Checked for spark - ok
Checked for fuel injector power - ok
Checked for fuel injection signal - ok
Check for blockage in injector - ok
Re-flashed E-85 tune file - no change
Flashed 93 octane tune - no change
I can’t tell whether or not it has E -85 or 93 octane in it
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
2015 coils are different from the 16-17 coils. Make sure you got the right ones ;)
Malfunctioning IMRCs as well as the VCTs will cause misfire codes too.
Also, I don’t know if it will help, but attached is the Misfire diagnosis from shop manual:
Jackson1320
California
Jaxson
2015 mustang gt
What plugs are you running. You might try bringing the gap down a little
Sadimsosad
Houston
Christian
2015 Mustang gt
Found that I was looking at the wrong coil. I was looking second from the drivers front and it was 4th from passenger front. Found that the coil had melted because it was getting a constant ground from the pcm So the coil was overheating.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Sadimsosad
Houston
Christian
2015 Mustang gt
and why was it getting a 'constant ground'?
I unplugged the pcm connector and it lost ground. I tested the wire between the coil and pcm and it’s got good resistance with no continuity to ground until I plug it in on the pcm side. These coils have a constant 12v from ignition in one side and the other wire should be a ground pulse that the pcm makes internally, so constant ground means failed pcm I think
Sadimsosad
Houston
Christian
2015 Mustang gt
See post #3.
Don’t think it’s an issue caused by the wrong coil because it is the same cylinder misfire before and after replacing coils. Also cyl #4 is the only one with a constant ground on the signal wire
