Mechanical Oil Pressure/Temp Gauges
TheHydro
Las Vegas
2015 GT Performance Pack
Is there an oil filter sandwich adapter that will fit to install oil pressure and temp gauges?
ahl395
Allan
TheHydro
Las Vegas
Thanks. I didn't know if one like that would work since it says it is for an external oil cooler
ahl395
Allan
Generally that is what theyre for, but if you cap off the inlet/outlet ports it should work fine for your purpose.
olaosunt
Indiana
I tried the Mishimoto and it will not work because there was not enough clearance with the oil filter.
I tried it on the KB car first and initially thought it was because the engine was lowered with mounts but it did not fit the Hellion car either .
I looked in to the MMR oil filter relocation kit(has 1/4 and 1/8 NPT fitting ) but ended using the one a glowfish adaptor with the glow shift gauages .
There was still not enough clearance so ended up removing the stock oil cooler (so far I have no issue with oil temp temps ).
http://www.glowshiftdirect.com/vehicle-specific-oil-filter-sender-adapter.aspx
olaosunt
Indiana
Sorry Glowshift NOT glowfish !
Lol
